Old 06-17-2019, 11:49 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
93 Excella wardrobe light
I need to replace or repair 1 of 3 wardrobe lights that is activated by opening the wardrobe door. Anybody have an extra or a replacement suggestion? Thanks
PS VTS does not have one and Inland RV is looking.
Old 06-17-2019, 12:32 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Check Out of Doors Mart, or Gamblers rv in Quartzsite Az.
Old 06-17-2019, 01:03 PM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have that same crummy light which works intermittent at best. The trouble seems to be the light socket itself which doesn't hold the bulb correctly.
I was thinking about soldering some wires to the light socket contacts and running a long strip of LED's down both sides of the doorway or use a couple of LED puck lights.
What do you think?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-17-2019, 01:44 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I did just that, the leds are much better.
My original light fixtures are going strong.... I used an aerosol spray called Caig DeOxit on the brass contacts, you could use Brasso to do the same thing.
Old 06-17-2019, 01:52 PM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
What do you think?
I bought some replacement LED bulb for the 561 festoon bulbs. Brighter and whiter light. That was a big improvement.
similar to these:
https://www.amazon.com/AUTOUS90-Fest...%2C167&sr=8-10
ps: Mine was working intermittently also. When I was replacing the bulbs I realized the bulb contacts had spread apart enough that the bulb was loose. I bent them a little tighter and they work great ever since then.
Alan
Old 06-17-2019, 02:54 PM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
What do you think?
In my case the problem is not the light socket but the actual button/ plunger switch which is not completing the circuit. But I agree the whole fixture is crummy.
If I could find a better switch that turns on when the wardrobe door is opened I would substitute some kind of good LED.
Old 06-18-2019, 10:01 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
FYI/ Found an LED replacement. Made by ITC called LED Closet Light Part number 69560. Available from Camping World and Sailor Sam's
http://www.itc-rv.com/product/led-closet-light/
Old 01-21-2020, 04:16 PM   #8
Birdsboro , Pennsylvania
Thumbs up Wardrobe light found
I just found the light that started this thread. Found it at Southwest Exchange in Yuma, Arizona. They even had three more on the shelf! These have been hard to find in stock anywhere, but are exact replacement for the original. I have a 2000 Excella. I use this with an LED replacement bulb.
Cdeggy is offline   Reply With Quote
2012 Interstate Dual Wardrobe, 2nd wardrobe removable? WillieJ Sprinter and B-van Forum 1 09-07-2016 09:14 AM
hinges on wardrobe losen bfwoz Cabinets, Counter Tops & Furnishings 5 10-08-2004 06:04 PM
Layout of wardrobe & chest of drawers jeanarlene General Interior Topics 2 09-30-2002 08:40 AM
Wardrobe/dresser replacement davidz71 General Interior Topics 2 07-25-2002 06:52 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
