07-20-2020, 06:46 PM
2012 27' FB International
Spokane
27FB BEd and nightstand removal
Hello! I am doing a few mods to my trailer and need to get the right nightstand out of the trailer to get at the wiring below. Any clues how to remove this from my 2012 27FB INT’l serenity?
Many thanks in advance.
03-07-2021, 03:58 PM
2013 27' Flying Cloud
Calgary
, Alberta
Hi there I am trying to do the same thing in my 2013 FC 27fb. Did you figure it out?
I see the screw at the top corner. It seems to release the back end. However I cannot find the screws for the front. I am going to go look at the parts catalog for clues.
Peter
03-07-2021, 04:51 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
In the door frame opening there are 4 screws directly into the wall through the plastic trim. Also 3 screws under the top through 1x1s into the walls
03-07-2021, 07:22 PM
Calgary
, Alberta
Thank you... I did not take the 10 seconds to pop the door off. I was focused on those 1x1s, which in mine do not have screws into the wall. I could not figure out what the 1x1s were for. I popped the three screws out behind the door and it came right off.
-Peter
03-08-2021, 07:38 AM
Spokane
I removed numerous screws and never got it to budge. It seemed screwed to the floor. Can you guys send pics?
03-08-2021, 12:07 PM
Calgary
, Alberta
Yes I will post pictures tonight. (currently at the office).
03-08-2021, 05:33 PM
GB
2016 27' International
Saint Cloud
Last screw holding it in.
There is a screw just below the cabinet top that is at the very front of the cabinet (at the point) going into the wall. You will access this from outside the cabinet.
I am converting my FBQ to a FB Twin. Almost done so all of my cabinets have come out.
Gil
Gil
03-08-2021, 05:56 PM
Calgary
, Alberta
Uploading three photos...
I had three screws at the front on the door frame and one at back top of the cabinet. I also included a photo of the 1x1s; however mine were not screwed into the wall.
Hope this helps
03-08-2021, 11:13 PM
Spokane
Hope this helps
Wow! Behind the door?! Okay, well I am on phase 2 of my solar project. This will be really helpful. Thanks very much.
03-28-2021, 05:54 PM
Spokane
Conduit under nightstand
Thanks for the post, o was able to remove my nightstand! Does anyone happen to know anything about the conduit under the nightstand and where it terminates?
03-29-2021, 10:31 AM
Calgary
, Alberta
No and I recently asked for Electrical schematics and like many others before me Airstream did not send them or even speak to them in their email response.
03-29-2021, 06:30 PM
Spokane
I guess I could take out a few rivets underneath and see... I shoved a Milwaukee boresight camera in there but it gets a little tight and I don't want to force it and get stuck. if there is a better route than running the inverter wiring externally I would rather do that. The solar wires are here that come from the roof and the RJ-45 that goes to the info panels at the galley. Has anyone removed the road side nightstand to see if there is a conduit there too?
