Old 05-15-2020, 07:59 PM   #1
andysherard
greenville , thomassherard
Zamp Solar Connection 2018 27í Flying Cloud FB
My 2018 27í Flying Cloud has been prewired for 450 watts of solar panels on the roof. Iíd like to use Renogy panels instead of Zamp. Iím looking for any advice on installation, new batteries, and how/where to install the battery monitor.
Thanks Andy
andysherard is offline   Reply With Quote
Old 05-15-2020, 08:49 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Hi Andy,
Just to clarify, are you referring to the Zamp three receptacle box on the roof? Some guys abandon that box and install another - there's several treads on that. AirMiles, another member has installed Renogy panels if I remember correctly. Search for his posts.
I recently installed a Victron BMV-712 in our 27' Globetrotter FBT in case you're interested: https://www.airforums.com/forums/f44...bt-206365.html
Good luck!
Jeff
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1500#
WBCCI# 10258
April 3, 2020 Retirement Plan RETIRED!
jeffmc306 is offline   Reply With Quote
Old 05-16-2020, 07:19 AM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Andy, there is no problem switching panel manufacturers on the factory prewire. I have six 100W panels on my 27' using the factory prewire. https://www.airforums.com/forums/f44...ml#post2288336 I use, and would recommend, a series-parallel configuration to minimize the voltage loss over the factory prewire. I recommend reading through the "Solar Show and Tell" thread to research different installations of solar and the issues and benefits of each. Here is a list of components I used on my 600W installation: https://www.airforums.com/forums/f44...ml#post2288472 If I were buying new panels, I would purchase Renogy Compact 100W panels. I have two Renogy Compact 100W panels on my mixed-panel 600W installation.
Batteries depend on your budget. If you want to spend $2,000 or more on batteries, I'd buy Battleborn Lithiums. If you want to spend $250 on batteries, I'd buy Duracell EGC2 6V golf cart batteries (or Trojan T105 batteries). I'm not a fan of AGM batteries as it doesn't cost much more to move up to Lithiums. So the battery choice to me is $250 for 180AH of usable wet-cell batteries or $2,000 for 200AH of usable Lithium batteries.
I've opened many cans of worms with this comment. There are many ways to add solar and all of this is discussed in the Solar Show and Tell Thread.
2018 GT27Q, 45 nights 9,860 miles, 600W Solar - Produced 75kWh, PD4655L, 6V Batteries, Champion DualFuel, ProPride&BOSP, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, 400W Solar - Produced 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(To RF)
AirMiles is offline   Reply With Quote
Old 05-16-2020, 11:19 AM   #4
andysherard
Thanks Jeff. Yes I would like to use the prewired three receptacle box.
Thanks Airmiles. Your post are the reason Iím looking at the Renogy panels. Is it possible to make a connector for the Renogy MC4 connector to plug into the existing Zamp three receptacle roof box? Or is it better to replace. Iíll reread some of your post.
Old 05-17-2020, 05:15 AM   #5
AirMiles's Avatar
You can buy an SAE-to-MC4 adapter. https://www.amazon.com/Adapter-16-5i.../dp/B07F1JMRSP or you can cut off the MC4 adapter and just use half of and SAE connection: https://www.amazon.com/Workman-Radio...VF6YX7DHB6Y56T
I cut an SAE connection in half and used both halves on AmSolar's recommendation. Make sure you get 10 gauge or thicker connectors.
(To RF)
Old 05-18-2020, 06:17 AM   #6
andysherard
Thanks Airmiles. Thatís exactly what I needed.
Old Today, 10:52 AM   #7
andysherard
Airmiles
Thanks again for all the links etc.. One more question, where did you end up putting your battery bank? Did you use the existing battery box? Is there a thumbnail I missed in all the post.
Old Today, 03:38 PM   #8
AirMiles's Avatar
I upgraded my batteries to 235AH Duracell EGC2 6V golf cart batteries. These are wet cell batteries that need to be in the original tongue mounted battery box. With 400W or 600W of solar, the batteries get fully charged during the day from solar while powering any daytime power so I have plenty of Amphours to run the furnace, fans, lights and some TV use at night. I’m willing to deeply discharge these batteries and use up to 180AH (80% depth of discharge). Golf cart batteries are designed for deep discharges. My batteries have been used for over 260 deep discharges and still test and perform as new. A pair of these batteries costs $250 at Sam’s Club. When these no longer have the ability to run my fans or furnace all night, I’ll just go to Sam’s and buy another set. To date, I’m at $1 per day of use which falls with each additional day of use. I’m on my third year with these batteries and am completely satisfied with their performance.
(To RF)
Old Today, 06:17 PM   #9
andysherard
Thanks for the comment on batteries. Iím about ready to dive into this project.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Zamp connection at battery? Jonmad 2016 - Current Flying Cloud 12 03-25-2020 07:04 AM
using instlled Zamp system with non Zamp products. mdlemieux Our Community 29 03-10-2020 05:19 PM
Zamp solar 200 watt portable solar charging kit Cascadian Airstream Classifieds 0 05-11-2018 08:13 PM
Connecting Renogy Suitcase to Zamp connection on 2017 Flying Cloud D44 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2017 11:43 AM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 02:25 PM
