Originally Posted by abqdor
Same problem. Went boondocking last weekend and battery would not hold a charge through the night. Luckily, I have a Honda 2000 generator to get us through. I typically run the generator for an hour in the evening and in the morning and batteries start out at 13.4v, but was down to 9.1 volts when we woke up and we did not run the heater during the night. We try to be frugal with power usage when boondocking
Factory batteries are less than two years old. I keep the trailer plugged in at the house, but keep the switch in the "Store" position and use a trickle charger on the batteries. I check the fluid levels regularly, so I thought I was doing everything right, but am now puzzled as to what is going on with the batteries.
9V at the battery terminals likely means they're toast, as has been said. 9V at your battery indicator inside *MIGHT* mean that, depends on your delta. Mine only runs about .2v lower, if memory serves. I'm paranoid and check the delta vs a reliable meter nearly every time we go out.
Do you have an inverter? If so, do you leave it on? I notice significant load with the inverter on but not driving anything... I think it's because the TVs and blu-ray player "wake up" and idle even though apparently off, plus the native inefficiency of the inverter. Still, I run my CPAP all night off the inverter (with the TVs unplugged) and the voltage doesn't drop enough to shut off the inverter, just makes ME feel bad to see it in the low 11v range by morning.
Some models of the refrigerator are said to have an unswitched
12v heating element to prevent condensation. That's worth looking into, if only to protect your next set of batteries.
