Hi - does anyone know what wires / cables are running through the frame on the tongue on the right hand side / passenger side? i installed a sway control base plate and might have scratched some wires inside the frame with the drill and not sure if I have a problem now. everything seems to still work. and have no clue how to access those wires?
Perhaps your 7-pin wiring. You can trace those hand over hand, start at the end of the 7-pin cable and work aft. You should be able to verify where the harness runs, visually.
On my Flying Cloud the 7-pin wiring runs through that part of the frame. I had the same concern installing the ball for the friction sway bar. So far all of the 7-pin functions are working.
