Old 05-28-2022, 08:47 PM   #1
Golden , Colorado
Question Wiring diagram pleeeease 🙏🏻
I am almost done with my solar system for my 1972 lane tacky overlander
But I want to make sure everything is wired correctly
I have an AC I want to run off shore power (dedicated circuit breaker)
I have 120v wiring for appliances
I have 12 v wiring for all else
I have a circuit breaker box (for 120v)
I have a fuse box (for 12v)
Lithium battery
Mppt
Renogy 3000w pure sine wave inverter charger
Solar panels
Shore power outlet
**DO I NEED A CONVERTER**
Mainly need to know how to wire the shore power to run the AC?
What/how do I wire the inverter/charger?
Currently I have:
Shore power -> inverter charger -> circuit breaker-> AC
IS THAT CORRECT?
Emmaggy is offline   Reply With Quote
Old 05-29-2022, 07:41 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If you are using an inverter/charger you don't need a converter. The inverter/charger will take care of those duties as well.
Richard
11018
richard5933 is offline   Reply With Quote
Old 05-29-2022, 09:00 AM   #3
1988 32' Excella
Robbinsville , New Jersey
Technically you have an inverter/converter/charger, just nobody actually says the "converter" part so you already have a converter and don't need another one.
It should be.
Shore power -> inverter charger -> circuit breaker box->breaker to AC and breaker to other outlets
Old 05-30-2022, 02:20 PM   #4
Golden , Colorado
THANK YOU that is what I have so it’s all wired properly I just have to figure out why the inverter charger faulted but I think it’s just basic troubleshooting now
It should be.
Old 05-30-2022, 05:36 PM   #5
1994 25' Excella
Did it fail? Has it ever worked?
On my Victron it was easy to inadvertently tap the wrong setting and turn off the charger portion. Have you double checked the settings and switch positions?
Richard
11018
Fridge and oven help 🙏🏻 Emmaggy Interior Restoration Forum 0 02-10-2022 08:36 AM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 13 04-07-2021 02:20 PM
1975 P30 wiring diagram (as promised) ... Hayseed Airstream Motorhome Forums 1 11-22-2012 02:28 PM
wiring diagram 120v brunoffrance Electrical - Systems, Generators, Batteries & Solar 3 02-08-2003 01:41 AM
Wiring Diagram Needed 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 07-29-2002 12:21 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
