Old 07-28-2019, 07:27 AM   #1
1970 27' Overlander
Lakeland , Florida
Wires
I am about ready to pull all the old 12v wiring and replace it. I am noticing there are two different size wires for the 12v, 14g and 12g. It looks like the outside marker lights are 14g and the interior wires for the say the lights are the bigger 12g.
* Do I need to do the same or can I use the same size for all?
* If so, can I use the smaller 14g, I plan on using all LED's in lights?
My plan is use a marine grade wire that has a protective sheath around the wires.
CraigCam is offline   Reply With Quote
Old 07-28-2019, 07:37 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Please use 12ga wire for all. The price difference is minimal.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 07-28-2019, 08:49 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Are you going over to LED lights at the same time? I certainly would suggest it if you are tearing into things. If so, the current involved will drop dramatically. Wire size is current related, you probably can get away with number 18 for the lights after an LED conversion. The main advantage is that it's easier to work with.
Indeed for stuff that pulls real power, you want nice beefy cabling. You do need to be a bit careful about what goes where.
Old 07-28-2019, 09:12 AM   #4
A W Warn's Avatar
rural , North Carolina
If you know how to calculate the load, you can use required wire gauge based on load.
If not, bigger (lower gauge number) is better.
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 1999 34' Excella, 2000 25' Safari)
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 04:10 PM
Where's the wires? HP9K Electrical - Systems, Generators, Batteries & Solar 5 09-03-2003 07:23 AM
replacing wires to overhead light jwaldin Electrical - Systems, Generators, Batteries & Solar 1 02-18-2003 07:52 AM
What are these........ wires for? niftypkg Electrical - Systems, Generators, Batteries & Solar 2 10-13-2002 01:21 PM
Wires to nowhere Craig Electrical - Systems, Generators, Batteries & Solar 3 10-01-2002 07:03 PM
