RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-07-2018, 02:50 PM   #1
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
Which set of wires goes to PD4655 ?
I have a 2014 FC 25 and I have two sets of wires coming into battery box and I'm trying to find the ones coming from the charger to test the voltage from the converter.
I have a red/black with rubber boots and clamp on terminals.
I also have a set with copper terminals. One of these wires is red and black?
When I turned on the PD4655 with the slow blinking light, I tested the set with the copper terminals and did not get a 13.2V reading.
How do I test the converter to see that it is working at the battery box?
thanks
dmbecke is offline   Reply With Quote
Old 05-07-2018, 02:55 PM   #2
2007 22' International CCD
Make sure use/store switch is in "USE"--else the battery charger may not be connected to the battery...
Old 05-07-2018, 03:24 PM   #3
Journeyman
2016 25' International
Deerfield , Massachusetts
thanks
Mine is a 2016. In mine, the wires from the charger go to the buss bars, NOT directly to the battery. One is red (almost pinkish) and the other is WHITE. Both are 4awg.
The wires that come from the battery are two sets: the one with the clamps goes to the bus bars. The heavier one without goes to to the inverter.
I hope that helps.
thiel is offline   Reply With Quote
Old 05-07-2018, 03:31 PM   #4
dmbecke's Avatar
I hope that helps.
OK, thanks
So, I can I test my converter at the batteries ?
I would think somehow an appropriate charging voltage is making it to the batteries? I'm assuming the test is to use a multimeter at the rubber booted bus bar connecters?
Old 05-07-2018, 07:03 PM   #5
Journeyman
OK, thanks
Yes if you are charging your batteries you should see that charge voltage showing up right at the batteries themselves.
Also, if the 12v items inside the trailer are working off of shore power then your converter is working.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 05:10 PM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 09:37 AM
which goes first? bullydogsmom Belly Pans & Banana Wraps 20 06-19-2009 11:13 AM
Furnace goes on, TV goes off whacksplat General Repair Forum 11 05-17-2009 08:33 AM
2 wires for brakes, what goes where? greenrig Brakes & Brake Controllers 3 10-28-2008 09:57 AM
