Hi,
Attached photo is a fuse block I found inside a
12v panel box of a 2021
Caravel, I am trying to figure out the wiring but I am having hard time understand the connection inside the fuse block.
Some questions -
- What's the the name/brand of this fuse block?
- 1 and 2 are connected with fuse F1, same for 4 and 5(F2), 5 and 6(F3) right?
- What about the blue wire 3? Is it connected with C on top?
- Is 1 also connected with A, 2 with B, etc - the top row connected with ones on bottom row in the same column?
- What's the purpose of the 2 holes under D and E or above 7 and 8?
- 9 and 10 (yellow & red wires) are just about 8 inch long wire with open end, nothing connects to them. What's the purpose of them?
So basically this works like breadboard, connectors in same column are connected and fuse blades are used to connect between columns next to each other?
Thanks in advance!
