06-27-2021, 12:22 PM
San Diego
, CA
What is this porcelain gizmo on my breaker panel?
See attached photos - this porcelain gizmo attached to my 2x20amp breaker panel - what is it? Has a couple red wires coming out of the back.
06-27-2021, 03:13 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
Someone might recognize it but your both photos are too far out of focus for me to clearly see it. A wild guess is it may be a rheostat.
06-27-2021, 03:26 PM
1966 22' Safari
Fredericksburg
It’s mounted on the top of the breaker box with a small bulb and wired in the box. I don’t remember if it stays lit when there’s power to the box or lights up when the shore power has an issue with polarity.
06-27-2021, 06:06 PM
TAC OK-2
1963 19' Globetrotter
Jones
, Oklahoma
It's a polarity indicator. Lets you know if your trailer is plugged into shore power correctly.
06-27-2021, 06:30 PM
Sag Harbor
, New York
Welcome to the forum.
Do you have the printed manual? On the lower right corner of p. 11-1 of this one, for a 1964 Overlander 26' Twin, it confirms this is a polarity indicator light, which should be off if the shore power is working correctly. [PDF p. 63/78]
https://www.airstream.com/wp-content...s-book-423.pdf
06-27-2021, 10:23 PM
San Diego
, CA
Indeed, it is a polarity indicator. One pole attached to the trailer body, one pole attached to the ground bus bar in the panel. It would illuminate if reverse polarity.
I'm actually not new to the forums, I've been here a decade or so. At some point we switched over to "RVLife" and apparently my old name (photomikey) is lost to time.
06-28-2021, 12:33 AM
Sag Harbor
, New York
Welcome back!
Here is your last thread from early 2020:
https://www.airforums.com/forums/f45...ng-205305.html
By clicking on your user name on the left side of a post, you can "Find More Posts" in the drop-down menu.
Have fun with the new Overlander.
Peter
06-28-2021, 10:32 AM
1986 25' Sovereign
Huntsville
, Alabama
As kind of a side note has anyone noticed how OTRA15 can whiz around and find information from nowhere on the forms and post links?Great job Peter.
06-28-2021, 11:25 AM
Sag Harbor
, New York
Thanks . . . a bored retired old guy with too much spare time?
06-28-2021, 12:18 PM
2019 25' International
Washington
, Washington, D.C.
Streamracer - I was thinking the EXACT same thing about OTRA15's uncanny ability to methodically, uncritically direct people to where they need to go.
06-28-2021, 12:27 PM
Sag Harbor
, New York
Thanks.
06-28-2021, 07:32 PM
1988 32' Excella
Robbinsville
, New Jersey
Yes and if your trailer is plugged into an outlet with reversed polarity the shell would now be carrying a small electric charge and shock you if you touch it when you are grounded. Shouldn't be dangerous for a healthy adult, watch out for pets and people with pacemakers or other electronics surgically installed.
07-08-2021, 05:33 AM
1973 Dodge Cayo Motovator
Dahlonega
, Georgia
That is true only if the neutral (white) is INCORRECTLY bonded to the trailer frame. Unlike stationary house wiring, neutral is NEVER bonded (connected) to the trailer frame . Only the green/yellow wire should connect to the trailer frame.
I also disagree that the shock is harmless, it can be fatal. Do not ignore this issue if it occurs.
07-09-2021, 06:16 AM
KW
, Ontario
Too bad they don't include those anymore. Would have helped some folks. We include them on all our electrical panels that we build.
07-09-2021, 07:45 AM
Sag Harbor
, New York
Thanks for this:
We leave the following inexpensive polarity indicator plugged into the 120-volt shore power outlet above the fridge:
https://www.amazon.com/Power-Gear-Re...5838104&sr=8-2
. . . where it is visible from most of the trailer, as well as through the dinette window right after connecting shore power.
Does this device do the same thing, as that old AS OEM light, in effect?
Peter
PS -- And don't the Progressive EMS devices perform a similar polarity test internally?
07-09-2021, 10:36 AM
2020 25' Flying Cloud
Chula Vista
Originally Posted by OTRA15
Thanks for this:
Peter
I have something similar. I plugged it into the outlet next to the door. Easy to check when entering the trailer.
07-09-2021, 10:58 AM
1988 32' Excella
Robbinsville
, New Jersey
Not what I said. The reverse polarity light would connect a small charge (through the light so only a few watts) from the neutral line to the ground, this amount of current would be fairly harmless to most healthy adults. IF you search well enough you can find a couple threads about someone kneeling, sitting or laying on the ground and touching their trailer and feeling a tingle that was traced back to a reverse polarity light.
If the neutral and ground were bonded with the polarity reversed yes that would be dangerous to anyone.
