Old 09-26-2022, 07:58 AM   #1
2004 25' Classic
LaPlata , Missouri
What is this for?
There is an electrical connection point on the front of our 2004 25' classic RB, behind the propane tanks. What is it for? See picture. Thanks.
PEJensen is offline   Reply With Quote
Old 09-26-2022, 08:04 AM   #2
1949 22' Liner
1969 27' Overlander
1969 27' Overlander
Walnut Creek , California
The original shore power port.
Jcondon is offline   Reply With Quote
Old 09-26-2022, 08:16 AM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Remote generator hook up. Here's the text from page G-44 in the Airstream manual for your trailer, assuming it's the 2004 Classic.
Name:	Screen Shot 2022-09-26 at 08.13.53.jpg
Richard
11018
richard5933 is offline   Reply With Quote
Old 09-26-2022, 08:20 AM   #4
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
Hi - It's a secondary power connection for a generator. If the generator is in the TV the cord just connects at the front of the trailer rather than having to try and reach the connection at the other end.
Take a look in your trunk on the street side...you'll probably find an access door that swings up. Behind the door is access to your transfer switch that controls which power port provides shore power to the trailer.
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 09-26-2022, 08:24 AM   #5
2022 28' International
Mercer County , New Jersey
For some years, the trailers have 2 shore power ports - one on the front for a generator and one on the side for a power post.
jeffb831 is offline   Reply With Quote
Old 09-26-2022, 08:54 AM   #6
1949 22' Liner
1969 27' Overlander
1969 27' Overlander
Yes, Either can be used for shore power.
Old 09-26-2022, 10:12 AM   #7
2017 25' International
West Lake Hills , Texas
...but not at the same time. An existing automatic transfer switch should prevent this but don't try it. At some campgrounds and at my home I have to use the front power inlet.
Fungus is offline   Reply With Quote
Old 09-26-2022, 11:40 AM   #8
1988 32' Excella
Robbinsville , New Jersey
Also it was only on 30 amp trailers from factory. Either could be used for shore power or generator, just to make it more convenient (use the one that is closer) and the front one could be used with an inverter from the TV.
Some have had the transfer switch fail and needed to only use one (usually the front connection) until fixed or it failed so neither one worked.
Old 09-26-2022, 12:52 PM   #9
Mollysdad's Avatar
I thought it was a great idea, but it's only on 30 amp models.
Old 09-26-2022, 05:04 PM   #10
1949 22' Liner
1969 27' Overlander
1969 27' Overlander
I have seen lot's of them in use when the trailers are parked at home. I like choices!
Old 09-26-2022, 05:49 PM   #11
2004 25' Classic
LaPlata , Missouri
Thanks everyone. Now I know.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
