RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-03-2020, 01:02 PM   #1
Pasadena , California
What is this device?
Hello all,
I'm working on some rewiring and fixing a faulty battery disconnect. Can anybody tell me what the device and the attached picture is? Thanks so much.
mep67 is offline   Reply With Quote
Old 02-03-2020, 01:07 PM   #2
Long Island , New York
Welcome to the forum!
Is this in a trailer or motorized RV? Your 2008 Bambi 19' maybe, or the tow vehicle?
More details would help with the diagnosis IMO.
Good luck,
Peter
Old 02-03-2020, 01:15 PM   #3
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
That's the battery disconnect that is controlled by your use/store switch.--Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is online now   Reply With Quote
Old 02-03-2020, 01:44 PM   #4
batman's Avatar
1964 22' Safari
modesto , California
Yep. The term would be a "contactor".
The contactor is the relay to use when a circuit must support a heavy current load.
-Dennis
batman is offline   Reply With Quote
Old 02-03-2020, 02:57 PM   #5
Okay, thanks for the reply. So this is it's just a battery disconnect? In other words, This is not a battery isolation manager at all? I'm trying to figure out how to convert over to lithium batteries and was not sure if the trailer has a battery isolation manager. By the way, it's a 19 ft Bambi 2007. Thanks again.
Old 02-03-2020, 03:00 PM   #6
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
It does not disconnect from ALL loads, which varies according to anecdotes. Definitely the propane detector not isolated, some say subwoofer, others say inverter stand by, etc.
You need to install a dedicated switch in between the batteries and this disconnect switch if you totally want to isolate the batteries. My T105 flooded 6V batteries have been in storage for 8 weeks in winter temps totally isolated, and still holding 12.74v when I check on them. Blue Seas is the switch of choice for most on this forum.
pcskier is offline   Reply With Quote
Old 02-06-2020, 11:59 AM   #7
2018 26' Flying Cloud
Oriental , North Carolina
I noticed the left hand red wire is loose with the nut not tightened. Hopefully this has been tightened or else you will have sparks and intermittent contact.
Captn.Ken is offline   Reply With Quote
Old 02-06-2020, 09:54 PM   #8
2017 30' International
Lincolnwood , Illinois
Good catch !
Milo1952 is offline   Reply With Quote
Old 02-07-2020, 01:53 PM   #9
2014 27' FB International
Clearwater , Florida
My 2014 had battery store/use charging issues the pictured relay/contactor was replaced under warranty.
ChuckFeldt is offline   Reply With Quote
Old 02-08-2020, 08:17 PM   #10
Thanks for everyone's responses. I ended up taking the whole thing out because it wasn't working. This was actually the second malfunctioning one I had. Anyways, installed one of the bluesea switches and works great. Thanks for your help.
Old 02-09-2020, 08:48 AM   #11
2018 25' International
Slidell , Louisiana
The AS supplied contactor/relay is a fairly cheap and unique device because it does not consume power for the solenoid as it is momentary in both throws. It has a swing shaft and a spring to catch it in the open position, but it can get "stuck". Rap on it gently with a rubber mallot or vigorously shake it while attempting to energize it. Should work for another 100 cycles after that.
Old 02-09-2020, 09:25 AM   #12
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
In the USN we used to call that a "horizontal slam adjust". I use it often....
Larry
lsbrodsky is offline   Reply With Quote
Old 02-09-2020, 10:49 AM   #13
2007 22' International CCD
In the 60’s and 70’s, we Navy data systems and electronic tech types referred to it as “percussive tuning”.
rmkrum is online now   Reply With Quote
Old 02-12-2020, 12:55 PM   #14
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah , NSW Australia
Hello all,
It will not be connected at all very soon if that nut falls right off
Tony Lee is offline   Reply With Quote
Old 02-12-2020, 08:11 PM   #15
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hello all,
You found it. The battery disconnect. Looks like the wire on the left is loose.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
SuperTrouper is offline   Reply With Quote
Electrical Wire Colors Equals What Device gean235 Electrical - Systems, Generators, Batteries & Solar 16 02-12-2020 01:31 PM
Ant-theft device for all r.v.'s Jim Jarzabek Off Topic Forum 20 04-28-2016 05:56 PM
Breakaway Device HansenClan Brakes & Brake Controllers 21 08-24-2008 05:50 PM
Automatic Load Shed Device 68 Overlander Commercial Listings 2 12-12-2006 11:28 AM
Where is the anti sway device located/electric brakes? Mrcrowley Electrical - Systems, Generators, Batteries & Solar 19 07-07-2006 01:40 PM
