Greetings from Colorado and welcome to these Airstream Forums. You can learn all about renovating your 78
Sovereign here. Check out the Knowledge Base, Airstream Trailer Forums at the bottom of the Forums page. Then click on
Sovereign and your year range. Now start reading and see how others have prepared their trailers for full time living.
I helped a friend renovate his 76 Sovereign 31', and I have renovated a 75 Overlander 27', a 69 Globetrotter 21', and a 66 Trade Wind 24'. Crazy I am.
Here is the wiring diagram for the 66 Trade Wind. It is not necessarily relevant to your project, but if you start with the battery and trace every wire you will get a feel for it. It is basic wiring for sure.
Basically your trailer is 12v battery powered. The battery will power maybe 4 separate wire circuits. Each of the 4 circuits is protected by a fuse. Then Airstream added a 120v power panel so you can plug in the trailer and use 120 volt outlets, or an air conditioner, or more importantly a battery charger for the 12v battery. This transformer is called a "converter" as it converts 120v to 12v just like a car battery charger.
I told a friend once that you have to identify the function of every wire in your trailer. So as you disassemble to replace, identify every wire you take out; from the positive battery cable, to the wire that powers the water pump, to the marker lights on the outside of the trailer, etc, etc. Then we marked on the wall where we needed a 12v wire to power a light, a fridge control, a water heater control, a furnace fan, a roof vent fan, or even a tail light. There is a lot of stuff needing power. We did the same for all the places we wanted 120v power like the air conditioner, the converter, the outlets, etc.
David
