Old 08-23-2018, 09:54 AM   #1
1984 27' Sovereign
Austin , TX
Water Pump Blows Fuse
When I turn on the water pump switch it blows the fuse. I connected the pump to a car battery and it's turning over so it doesn't appear to be drawing too many amps. I left the pump disconnected and it still blows the fuse. I'm hoping someone with experience can help me out. Thanks in advance!
Danno99 is offline   Reply With Quote
Old 08-23-2018, 10:21 AM   #2
2016 28' International
2015 28' International
2013 28' International
Las Vegas , Nevada
You have a short, in your switch (hopefully) or in the wire harness between the switch and pump. Disconnect the wires (cut) from the back of the switch, turn on the switch and hope it still blows the fuse, otherwise you are looking at the wire harness shorted somewhere.
Good luck and happy airstreaming!
vintagemotor is offline   Reply With Quote
Old 08-23-2018, 11:59 AM   #3
1984 27' Sovereign
Austin , TX
Thank you for the response. I'll give it a try and see what happens. I'm hoping you're right and it's not the wiring harness.
Old 08-23-2018, 12:11 PM   #4
2007 22' International CCD
Another thought.
The pump motor may turn over when you have it connected directly to a battery, but that does not mean it is working correctly.
Try the same test with the same rated fuse in the Airstream pump circuit in series with the battery. If the pump motor is going bad and drawing excess current, the fuse will blow. If it runs properly without blowing the fuse, its probably good.
Old 08-23-2018, 01:25 PM   #5
1984 27' Sovereign
Austin , TX
Good point rmkrum. I'll give that a try as well.
Old 08-23-2018, 01:43 PM   #6
A W Warn's Avatar
Two Places , Sticks & Bricks
In post #1 you said "I left the pump disconnected and it still blows the fuse." If flipping the switch with the pump out of the circuit still blows the fuse, that eliminates the pump as the problem. Only things left are switchs or wiring.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 08-23-2018, 02:08 PM   #7
True that...
Worth a check--as a bad pump can eventually toast wiring as well...
If it is a wire in the wall, it's going to be a mother bear to find the problem or replace the wire...
Old 08-23-2018, 02:09 PM   #8
Cicero , Indiana
Can I jump in with another pump question here? I picked up a ‘75 Safari 23’ with the original water pump. It was working when I left, but now fails to turn. Breaker is fine, fuses look fine in the 12v box, and the switch light on the panel comes on when I flip it. But alas. No pump action. I was gonna Jam my head back in there when I got a free minute to see if anything banged loose on all the driving I’ve been doing with it. Any advice is appreciated. :-)
justplaincor is offline   Reply With Quote
Old 08-23-2018, 02:21 PM   #9
Inspection is the first thing. Look for loose 12 volt supply wires between the switch and pump. Check for a properly-connected ground wire as well. Closely inspect for corrosion and toasted insulation.
Verify that the pressure switch on the pump is working properly--it should be closed (so power will get to the pump) when the pressure is low.
If the pump motor has obvious brush holder caps, pull the brushes and see if they are the right length. Most pumps I've seen don't have brush caps, but a look doesn't hurt if it has them.
All else fails, pull the pump, try it with a properly rated fuse in series and connect right to the battery. If it then runs, the issue is somewhere in the wiring.
Old 08-23-2018, 06:55 PM   #10
1984 27' Sovereign
Austin , TX
Originally Posted by rmkrum View Post
True that...
I’m going to pull the switches this weekend to see if that’s the problem. I fear that it is the wiring in the wall and like you said it’s going to be a pain to replace it.
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 5 11-14-2021 05:17 AM
2012 FC Range Fan/Vent Blows Fuse flyingcloud 2009-2015 Flying Cloud 19 03-27-2014 02:57 PM
Suburban NT32C blows fuse after a few seconds hertfordnc Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-29-2010 04:25 PM
Dometic RM2501 constantly runs the igniter? blows fuse... WineStream Refrigerators 19 08-30-2009 07:09 PM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
