Old 07-27-2021, 05:26 PM   #1
2018 25' Flying Cloud
Provo , Utah
Victron Multiplus and the Existing Transfer Switch
I'm removing my lead acid batteries and replacing then with lithium. As part of the project, I'm using a Victron Multiplus 3kW inverter/converter. I've located the existing inverter. The wiring diagram says that the existing converter is wired internally to the power panel, so I'll need to dig a bit for that.
The question I have is whether I can/should remove the existing transfer switch. From the Victron datasheets, it appears that the Victron acts as a transfer switch in its "no break" main A/C output. (the second A/C output only has power when the unit has input A/C power) So it seems the existing transfer switch should be removed.
Thoughts?
jranck is offline   Reply With Quote
Old 07-27-2021, 10:58 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yes, the existing inverter goes away along with the transfer switch.
Have you seen the new multiplus-II 2 X 120v?
It simplifies wiring a 50A trailer. Take a look.
wulfraat is offline   Reply With Quote
Old 07-28-2021, 06:42 AM   #3
Provo , Utah
I'll remove the converter, of course, but what about the transfer switch? I think it too should be removed, but wanted to see what others had done.
Old 07-28-2021, 06:55 AM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I just installed the “NEW” MultiPlus II 240/120 and we are using it the week for the first time. It’s performed flawlessly.
I will be using it extensively for the next 3 months and we travel the west.
I provide a detailed report once testing has some legs. #notsponsored
ID:	400561   Click image for larger version
Old 07-28-2021, 07:59 AM   #5
Provo , Utah
The place I purchased the MultiPlus from didn't have any of the MultiPlus II in stock, so I ended up with the older model. We have a trip planned and since the batteries in the trailer we purchased are shot, I needed the upgrade sooner rather than later.
I'm hoping that we won't miss much by having the older model.
Old 07-28-2021, 08:11 AM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
We've got one of the Multiplus II 2 x 120v inverters fro Victron and I agree with you totally. It made the install on a 50-amp coach very simple, and it's great that it knows whether we're on single phase 30-amp or split phase 50-amp service.
Only downside I've found so far is that it only monitors the current flow on L1, not L2. On L2 it only passes it through to the breaker panel but does nothing else.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 07-28-2021, 11:15 AM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
If you have a plug on the front of the trailer for a generator you will need the original transfer switch to isolate the shore power from the generator. The viltron transfer switch isolates the inverter from the shore power. All this is designed to protect the grid from external power inputs. That is a very real problem for linemen working on the grid.
guskmg
Old 07-28-2021, 11:22 AM   #8
2013 27' Flying Cloud
Calgary , Alberta
Not sure if you have the second power outlet at the front of the trailer that is intended for connecting external generator. My 27FB does and that is what the transfer switch actually switches between. If you have this then I think that you need to connect your the power out of the transfer switch to the AC in on the Multiplus. I have a picture on another post of how I did it.
Peter C is offline   Reply With Quote
Old 07-28-2021, 11:29 AM   #9
Calgary , Alberta
He is a link to the other thread with pictures. Note I did not have factory inverter.
https://www.airforums.com/forums/f44...te-220486.html
I also left the factory converter in place and just disconnected the power to it. If the multiplus dies I like the option in a pinch to be able to swap back to stock.
Old 07-28-2021, 11:37 AM   #10
Provo , Utah
GusKMG and Peter C have the right of it. After I started taking things apart, I realized that the existing transfer switch isolates the two coach inputs (one on the side toward the back and the one on the front) from each other, which the schematic labels shore power and generator inputs.
What I need to do is relocate the transfer switch by the multiplus and have the output of the transfer switch be the 120 input to the multiplus and then the 120 output of the multiplus go to the distribution panel in place of the existing transfer switch output.
Old 07-28-2021, 01:47 PM   #11
2011 27' FB Classic
Houston , TX
Not to hijack this thread, but I have a situation where I think my transfer switch must have blown: I can use the generator input just fine, but the side input is shot. Is there any meaningful risk in running it like this? With the one side down, am on borrowed time with the other side?
SS-Houston is offline   Reply With Quote
Old 07-28-2021, 03:19 PM   #12
Provo , Utah
@SS-Housten:
If it were me, I would drag out my multimeter and test whether you have power coming into the transfer switch from the "blown" input. If not, then the problem isn't the transfer switch. It is somewhere between the transfer switch and the input.
Old 07-28-2021, 10:56 PM   #13
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
Transfer Switch removal
Guskmg & Peter C have it correct. Don’t remove transfer switch. If you want to take advantage of the “hybrid” function of the Victron-one of its coolest features (draws power from batteries when input AC is low) you must have ALL A/C devices (including all outlets) powered through the inverter.
Gulliver72 is offline   Reply With Quote
Old 07-31-2021, 07:22 AM   #14
Provo , Utah
For those who care, here's how the multiplus will be wired. The factory wiring is shown by the dashed arrow between the transfer switch and distribution panel.
To wire in the multiplus, the output of the transfer switch is wired to the 120 input of the multiplus. The 120 output of the multiplus is wired into the distribution panel in the same way that the transfer switch comes from the factory.
Gulliver72 is correct in that you also want all AC power devices powered through the distribution panel. To accomplish that, in my panel I can use either circuit 2 or circuit 4.
Circuit 2 was used to power the old converter. When I removed the old converter, that circuit became an empty 15 amp breaker. To use that one, I'd need to run a wire from the circuit 2 breaker to the curb side, front corner of the coach where the wire that ties all the old inverter powered receptacles terminates and tie the two wires together in a junction box.
Circuit 4, also 15 amp, was used to power the old inverter as well as all the receptacles that were powered by the old inverter (i.e., via the inverter). The 120 wire that ties all the old inverter powered receptacles together and the old inverter power both terminate in the curb side front corner of the coach. It is a simple matter to tie the two wires together in a junction box, so that is probably what I'll do.
Name:	Multiplus 120 wiring diagram.jpg
12/3000 Victron Multiplus AC in and out wiring Peter C Batteries, Univolts, Converters & Inverters 5 03-09-2021 10:11 AM
Victron MultiPlus 3000 overheating SeaLevel Generators & Solar Power 28 03-30-2020 12:22 AM
Idle draw of Multiplus 2000 and Multiplus 3000 Dave-n-Janet Generators & Solar Power 10 11-24-2019 06:04 AM
Operation of victron multiplus inverter when below freezing fran&frank Batteries, Univolts, Converters & Inverters 34 11-11-2019 03:06 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
