Old 07-13-2020, 06:18 PM   #1
2019 25' International
Providence , Rhode Island
Question Victron BMV-712 Smart w/ AS AGM batteries
I just installed the victron into the trailer and it's working as expected.
I see a lot of profiles for flooded batteries and lithium, but no common info regarding the FACTORY batteries i.e. 2 12Volts lifelines in parallel at 160 AH with factory solar.
It still has the factory 1000w inverter.... so I'm trying to understand what the profile should be in the battery section for the AGM batteries should be.
Does anyone have this info to match this setup?
Chris
kittmaster is offline   Reply With Quote
Old 07-14-2020, 08:36 AM   #2
I looked at the lifeline battery specs and there is nothing there to put in the settings.....
Anyone know how this is normally done?
I'll be giving Victron a call later to see if they can help advise.
Old 07-14-2020, 09:01 AM   #3
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I got it from AM Solarís site
Hey Kittmaster,
When I installed my Victron BMV-712 I searched all over for the same information and found it on AM Solarís site.
Hope this helps!
Jeff
ID:	372868   Click image for larger version
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 07-14-2020, 05:57 PM   #4
Hi Jeff,
I did see that, wasn't too sure how accurate it was because I couldn't see others that used the data they are showing.
I did input the values shown, but if anyone follows our suit, the thing to remember is I didn't get the temperature sensor with the package from Amazon, so their settings for temp input would be erroneous unless of course you buy temp sensor.
I did buy it after the fact no knowing that it would be a "nice to have", so waiting for it to be delivered.
I am "thinking" is that these settings were for "AM solar" installation packages they offer and not a regular Joe buying off of Amazon?
So that is why I figured I'd ask here.
I assume you have used these settings.....do they seem accurate to you from your experience?
Thanks for the help!!
Chris
Old 07-15-2020, 08:05 AM   #5
jeffmc306's Avatar
McHenry , Illinois
Chris, glad you were aware of the AM Solar stuff. I did use these settings for my setup and so far, have no reason to doubt they're accurate. I assumed there's no difference between an AGM installed by AM Solar or any Joe.
I also considered purchasing the temp sensor but decided to hold off until adding Lithium (if ever). DW isn't enamored with boondocking so it might be a tough sell. Since I retired she's watching my "trailer mod budget" more closely!
I am considering replacing the factory Atkinson solar controller with a Victron so I can take advantage of their app and get better performance. The app is the reason I paid extra for the BMV-712 vs. a cheaper alternative.
Enjoy your new monitor!
-Jeff
2018 FC23FB
WBCCI# 10258
RETIRED!
Old 07-15-2020, 08:29 AM   #6
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The best reason to get rid of the Atkinson is that it is a piece of junk! It is basically on or off and is not the kind of multi-stage charger that any type of battery likes. Do yourself a favor and get the Victron now.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-15-2020, 05:54 PM   #7
Larry
Do you know if it is a direct swap that can be done at the factory?
Old 07-15-2020, 05:54 PM   #8
-Jeff
Thanks Jeff, you've been very helpful.
Chris
Victron BMV-712 Smart Battery Monitor Install&Review lzhome Generators & Solar Power 0 10-03-2019 05:05 AM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Sync settings for Lithium battteries - BMV-712 Smart waninae39 Generators & Solar Power 0 03-30-2018 12:58 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
