Old 04-20-2025, 01:35 PM   #1
RMNummi's Avatar
2014 23' International
2022 16' Basecamp
2017 23' International
Saint Petersburg , Florida
Victron 100-30 or 100-50?
I’ve got a 2020 GT 25 FBT. Mounting new Zamp Obsidians on the roof. What’s the difference between the 100/30 and 100/50? Planning on about 470 total watts. Have a single 300ah lifpo. Which MPPT?
RMNummi is offline   Reply With Quote
Old 04-20-2025, 02:35 PM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
The 100/50 gives you additional capacity if you need to add more panels. If cost is not the issue,go with the larger model
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,3x MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is online now   Reply With Quote
Old 04-20-2025, 05:07 PM   #3
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
The first number is the voltage, the second is the output current. With 420W the maximum output current is 35A, so I'd go with the 100|50 for the $60 difference (get the Smart, of course). There's a Victron calculator, which you get to pick panels or set custom parameters, but it mostly confuses me.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 04-21-2025, 07:14 AM   #4
RMNummi's Avatar
2022 16' Basecamp
Gracias Amigo.
RMNummi
TT: 25FBT Globetrotter
TV: 2023 Tundra 1794 Hybrid.
Old 04-21-2025, 08:43 AM   #5
Mollysdad's Avatar
My system looked to be about 30 amps. I went with the 100/50 just because.
Old 04-21-2025, 08:51 AM   #6
TrvlTin
2023 30' Globetrotter
Boulder , Colorado
Here’s a Helpful solar charge controller calculator
https://explorist.life/solar-charge-...er-calculator/
TrvlngTinTin is offline   Reply With Quote
Old 04-21-2025, 10:45 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Better to buy over sized once than have to upgrade to it later from an undersized unit.
Old 04-21-2025, 10:48 AM   #8
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you have a near dead battery at 11V
*and*
Have absolute max sun on your panels
*and*
Everything is 100% efficient
470W / 11V = 42A.
The 35A device isn't big enough.
The 100V vs something lower side depends on how you wire up your panels. With panels in parallel, you don't need 100V. If you decide to do some fun with series connections, it's a good idea to go that way.
The one thing that is for sure: It's way cheaper to buy the 50A device now than to buy the 35A and then replace it with the 50A later.
Old 04-22-2025, 06:08 AM   #9
RMNummi's Avatar
2022 16' Basecamp
Yup, 100/50 bought and delivered.
RMNummi
Old 04-22-2025, 07:47 AM   #10
2025 25' Flying Cloud
2024 Interstate 19
Noblesville , Indiana
Hi
*and*
*and*
470W / 11V = 42A.
Victron MPPT controller inherently limit current per a setting in the victron connect app / battery / limit current setting. If your solar array's output exceeds the controller's capacity, the MPPT will limit the output to its rated maximum (30A), effectively "clipping" the excess power. This ensures safe operation and protects your system components
vanderwielen is offline   Reply With Quote
Old 04-23-2025, 07:08 AM   #11
Half a Rivet Short
2022 Interstate 24X
Hi
Actually I believe they limit on power / temperature as well. They have a number of safety features built in.
The point in the post is: If you want the full output of your solar to go to the batteries you would need the bigger controller in the case shown.
Old 04-23-2025, 07:32 AM   #12
RMNummi's Avatar
2022 16' Basecamp
Good info. Thanks all. Went with the 100/50. Now to go find the Sunexplorer and swap it out.
RMNummi
AI19 Victron Buck Boost & Victron SmartShunt jhayesas Sprinter and B-van Forum 20 01-21-2024 06:53 AM
BMV comparison: Victron 712, Victron 700-02, v. Ali Battery Monitor JeffofCT Electrical - Systems, Generators, Batteries & Solar 9 09-16-2020 07:22 PM
Victron 100/30 vs Victron 100/20? smsasf Generators & Solar Power 0 08-04-2020 06:09 PM
Victron 100/30 and Victron 712 installer needed in PA RMD Generators & Solar Power 0 07-01-2020 09:08 AM
Unable to reconnect to Victron 100/20 marter Generators & Solar Power 41 10-13-2018 05:35 PM
