Use of inverter when powering AC with Generator
Hi
Specifics:
2019 25’ FC with 1 AC with Easy Start installed
Eu2200 Honda generator
Recently installed roof solar with Victron MultiPlus 3000, Victron Digital MultiControl, MPPT, BVM 712, new Lithium batteries, etc.
** my question is using the Honda generator to run the AC… with the new Victron electronics.
In our test today, using the generator and shore power, the Inverter had to be turned ON for AC and fan to work. Is this usual? Also, using the Digital multi control, do I set 15 or 30amp on the control display? The generator receptacle is 110v/15amp and my shore power today was at my barn 110. Can using the inverter harm the generator?
There is need for Inverter to be On for refrigerator also. I do not remember this with factory installed inverter/ converter.
Thank you very much,
Deb
