Old 07-03-2017, 04:07 AM   #1
2016 30' Flying Cloud
Sammamish , Washington
Upgrading to a PD 9270 in 2016 FC 30FB
Hi All,
I wanted to start my build thread so that I could bounce some feedback off the more experienced out there and hopefully this helps others too. I did this on on my 2016 FC 30FB.
This has been quite a project for me...I am really learning and happy that I made this decision.
I've considered the Powermax Boondocker but after reading several posts here and my personal research, decided to go with the PD 9270 install. The PD 9260 install should be just the same I believe.
First, like others have said, I made sure to test that all electrical is off. No shore power, batteries disconnected. I brought in an extension cord with work lamp, really helps along with a headlamp. Also, it really helped me to just take photos every once in awhile, to remember and analyze when I had questions for myself...and even on here.
Removing the old Parallax system was actually easy, just followed the bolts, screws (sometimes with allen wrench) and wires. Even the spliced black wire that has a twist on connector, the blue wire, the two white wires (one small and one thicker), just took everything off. I also took off the bottom-most fuse panel that's attached to the Parallax.
Since I wanted everything to look the same after the upgrade, I wanted to really work with the box the Parallax came in. The reason for this is that it has pre-drilled holes that work with the existing fuse panel and panel door underneath the fridge.
Taking apart and fashioning the old Parallax box took me a while and required bi-metal drill bits. I used 1/8" drill bit to first take off the rivets. I drilled down just slightly on the rivet heads and they come off fairly easy. After the top came off, I discarded it as I saw no purpose in putting it back on (the PD 9270 is already enclosed and would be additional hassle with wiring). Next, I took a T-15 screwdriver and took off the final screws that held the Parallax circuit board. I used a regular screwdriver for the fan and other areas. After just a few minutes, the entire guts of the Parallax was out.
I then needed a Dremel with cutting saw to cut down all the remaining screw mounts used for the parallax, so that the bottom of the stock box was as smooth as possible. After a little effort and grinding, I was left with a clean stock box to place the PD 9270. I lined up the PD 9270's fan with the hole in the clean box (formerly for the fan for the Parallax) and tried my best to give clearance all around, especially for the positive and negative terminals. Once oriented, it was time to mark, measure and drill some holes.
I placed the box inside the original space in the Airstream, and noticed that the sides of the box are met against another metal plate about 3.5 inches in from the front. That means that whatever holes I drilled, they needed to be at least 4 to 4.5 inches away from the front to clear. I used a 1 1/2 drill hole saw (a bi-metal bit) and purchased rubber grommets to fit from Lowe's specialty nuts/bolts drawer so no wires would catch on those shoddy holes. This seemed to work on both sides, one for the power cord, the other for the positive and negative wires. Hopefully the pictures show the work.
My last job today was to fashion a plug. One of the selling points of a PM Boondocker is that it is offered in a hard-wired configuration without voiding warranty (unlike the PD 9270, where if I cut the power cord to hard wire in it may void the warranty). Well it was fairly easy to make a plug thanks to others on the forum for a solution here.
I took a 14-gauge extension cord (the one where you can see 3 wires/channels making the cord, not the round 14 gauge). I cut the male end off (sorry there), and I was left with almost 6 feet of a female socket with wires that I intend to hard wire into the panel. The wires consist of green (ground), and (after researching and looking really carefully) one side is ribbed which is the neutral side and the other channel is smooth (the hot).
This is where I stopped because I now have questions. I'll go ahead and post pictures first of the work so far and ask again on a separate post....
ID:	288627   Click image for larger version
ID:	288629   Click image for larger version
2SIMBA is offline   Reply With Quote
Old 07-03-2017, 04:20 AM   #2
So really two issues I need some experienced folks to help me with:
(1) When I fashioned a female plug, I used a 14 gauge extension cord with female end. I know that the ground (green) goes to the "earth" ground bar on the panel, but where does the hot wire and the neutral wire go? I THINK the hot wire goes to the spliced black wires where I originally found the parallax connected to. Therefore I think the neutral will go to the bus bar with the other "white" wires. My lack of electrical knowledge has me tripped up...
(2) Most importantly, I'm lost on connecting the PD9270 now. I get the chassis ground, like the female plug above I'm running that to the "earth" ground bar on the panel. But does the positive and negative from the battery just go straight into the PD 9270? How do I connect the fuse panel?
I get confused with so much information out there on the internet, I feel I get overwhelmed and for my particular situation, it may not be correct. I'll post pics...looking for help and I thank you in advance!
ID:	288631   Click image for larger version
Old 07-03-2017, 04:34 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I hope you find someone who has done this and can tell you exactly how to hook it up, but I would caution those with minimal experience reading this that if you are going to remove something from your Airstream and replace it, you should trace out the connections first and understand what each wire is for. Put a label on it when you disconnect it. Airstream does some of their connections in strange ways and there are not schematics or connection diagrams available for everything in the trailer. There are certainly experienced people who have torn these things apart and put them back together so I hope someone chimes in to help.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-03-2017, 04:49 AM   #4
And sometimes the instructions aren't helpful either! I did take pics of the original setup. But I don't want the original setup! 😀
Old 07-06-2017, 11:42 AM   #5
Well....I did it!
I'd like to finish this thread especially for those who research...I want to be helpful for anyone looking at this.
That said, I believe that while researching these forums sometimes there is some misinformation out there regarding this install. That was a big reason I had many doubts on my install in the first place....when I shouldn't have. Just some caution for those that are inexperienced like me and may see what I saw.
So...I've confirmed that what you are doing is basically re-hooking all wire connections you take off. There is really no new connection I made except for one additional ground wire from the new PD9270 to the "earth" ground bar in the panel.
I also upgraded the old Parallax positive and negative wires to new positive and negative 6 gauge wire. I went to Lowe's for about 3 feet of it and was able to snake it through the panel just fine.
Note that you do NOT need to take off the positive and negative 6 AWG wires already installed to the fuse panel or the negative bus bar. Just the wires connected to the old parallax need to come off.
Related to the plug in I had to make....turns out that the hot wire goes in to the pigtail to the breakers (held together by a twist cap). When I worked on my International 23 for the PD4655 install, this pigtail was done incorrectly by airstream in that they pigtailed from the breaker....i.e. two wires were inserted into one breaker. My understanding is that is a big hazard, so I disconnected all wires to this breaker and did the pigtail correctly with 3 wires going into the twist cap leaving one wire for the one breaker. Hope I said that correctly
Pictures to prove, really happy I did this and she's working great! Thanks to everyone's help through posts and sharing knowledge over the years!!
ID:	288845   Click image for larger version
ID:	288847   Click image for larger version
Upgrading to 15" wheels on 2016 23' FC garylind Wheels, Hubs & Bearings 18 12-14-2016 04:55 AM
2016 Flying Cloud 30FB Wardrobes and Upper Storage ascrazy8 Airstream Classifieds 0 04-13-2016 01:02 PM
2008 Airstream Classic LTD 30FB King Colonial Airstream Commercial Listings 23 01-26-2016 07:29 AM
2016 Flying Cloud 30FB Couch / Sofa Bed + Decor Pillows ascrazy8 Airstream Classifieds 0 10-27-2015 01:57 PM
2016 Flying Cloud 30FB U-Dinette + Table + Base ascrazy8 Airstream Classifieds 0 10-27-2015 01:46 PM
