07-30-2005, 08:31 PM
SSOLID
1972 25' Tradewind
Fayetteville
Univolt Question? (Please look at pics)
I have a 72' 25ft Trade Wind.
The problem is I am not getting any power when I try to run strickly off the battery. Furthermore, I believe that the battery is not getting charged while I am plugged in based on meter testing.
I have removed the Univolt (way heavier than I thought it would be) and found that part of my problem was 2 blown fuses. These were not blown the last time I tried to wrestle this issue with the help of a shadetree electrician.
The Fuses that were lown were the Pink line in and the big 50 between the battery and the Univolt. I assume that is at least one of my problems in getting power from the battery.
Please take a look at the pictures and any info would be very much appreciated. I am a computer programmer and not an electrician so I am way out of my league here.
Steve
07-30-2005, 08:35 PM
SSOLID
1972 25' Tradewind
Fayetteville
Additional Pics
Here is the Univolt opened up..not sure what it is supposed to look like.
On a side note, does anyone know what will happen if I open up those valves? Also, what is that black, pump looking, thing above the valves in the first pic?
Thanks again to everyone for all your help.
Steve
07-30-2005, 11:24 PM
1975 Argosy 26
1963 24' Tradewind
Seattle
let's see..
Looks like the following:
valves open the pipes for draining in the winter time.
Hard to tell, but I think the pump is your BAL waterpump.
Probably time for a new converter - try "bestpower.com" for an intellipower replacement unit. It really is easy to replace it. If you do a search on "intellipower," I put in a wiring diagram ... your univolt is wired just like mine (some are wired different).
Good luck!
Marc
07-31-2005, 01:35 AM
LOST
, Hawaii
The pump looks like a squirrel cage blower, flange on the floor, is there a flex tube into the bathroom?
07-31-2005, 06:36 AM
, At Large
Sounds like...
You have a short in the #3 circuit. Replace the 50 amp fuse, that is a main power fuse, and nothing much will happen without it.
After you do that, check the stuff that circuit #3 protects, and see if anything looks "off". Little burn, or scorch, marks at lights, a fan that doesn't run, that used to, "funny electrical" smells, etc. Contrary to popular belief, fuses don't just blow for no reason.
The red-handled valves are drain and shut-off valves for the water in your coach, and the blower fan is to(hopefully) keep your holding tanks from turning into foul-smelling blocks of ice in the winter.
07-31-2005, 07:27 AM
Yes, fuses do not blow for no reason at all. Something caused it to blow.
Make sure you replace just the main fuse first. Then look for anything that blew the secondary fuse.
I consider the converter to be a safety item. I replaced mine in every Argosy I have restored. I do it out of habit now. Plus the old Uni-Volt is not the greatest with keeping batteries from going bad. The IntelliPower with a Charge Wizard will take care of that.
www.bestconverter.com also has a new converter that has something like the Charge Wizard built into it. A buddy of mine just installed one. Not sure how it is compared to the IntelliPower.
07-31-2005, 06:10 PM
Bump
Originally Posted by ssolid
...Also, what is that black, pump looking, thing above the valves in the first pic?...
I believe that is a vent fan to keep odors in the bathroom from permeating the interior. There should be a switch somewhere to turn it on.
08-01-2005, 11:28 AM
SSOLID
1972 25' Tradewind
Fayetteville
Black Pump?
You all are correct. I traced it back to a "fart fan" near the toilet.
Are the valves there to let water into the black tank or are they the ones that go to my faucet and shower?
(the univolt and valves, etc are in the curbside rear corner. and the bathroom is in the rear)
If those don't go to the black tank....Is there any way to fill the tank quickly to flush it out a few times? (beside running a hose through the window or trailer?
Steve
08-01-2005, 02:25 PM
1972 27' Overlander
Longmont
hi- yes, in the rear upper hatch there is a clean-out fitting in the black vertical vent pipe, at least in mine. stick a hose in there and flush away.
08-01-2005, 03:06 PM
Remember, Safety Third
Catfish Corners
Steve, did you get everything you needed concerning the Univolt? Lou has the right idea. Replace the thing. That's what I'm going to do as part of my rebuild. There is a member here who sells the Intelli-power and offers a discount to forum members, although I can never remeber his name/handle. Somebody will chime in with the answer. This time, I'll remember to bookmark the response!
08-01-2005, 03:12 PM
bestconverter.com?
68 Overlander?
08-01-2005, 09:51 PM
SSOLID
1972 25' Tradewind
Fayetteville
bestconverter.com
I went to bestconverter.com and the Intelli- Power units come in 30 40 and 45 Amp versions.
Which one do I need? I assumed I would get the 60 Amp. Is that too much power?
Steve
08-01-2005, 10:20 PM
1972 25' Tradewind
Lake Worth
I have the same trailer as you. I redid the bathroom (know it well) and also replaced the intelli with the 80amp. model. If noting has been changed there is a line running out the bottom of your trailer and the one knob will alow water to flow out of the trailer. There is nothing that comes into play with the black tank. That is all by itself. I have pictures of all that stuff if you need anything. I also switched the layout of my wiring so it all ran to the front of the trailer. I had all the wall panels out anyway so it made it easy to do. I've had the inteli-power in for about 6months and I think I ran into my first problem. When I was pluged into land line power and was using a havey load (12volt) after I turned the load off you would hear the fan on the intelli kick on... I can't get it to kick in now. I checked the fuses and all conections and I can't get it to kick on.
08-01-2005, 10:25 PM
1972 25' Tradewind
Lake Worth
More photo's of the wiring. I also added surround sound, DVD,LCD,MP3.. and a wireless network using my apple. It all can run on 12v power. Hope the pictures show up.
08-01-2005, 10:35 PM
1972 25' Tradewind
Lake Worth
Some more pictures of it done...
08-01-2005, 10:45 PM
1972 25' Tradewind
Lake Worth
Sorry I tried to fix some of the spelling in my first post but wasn't able. It's almost 1am here. I'm in West Palm if you ever need any help with your A/S... I've had it off the frame and back-on... I know it way better then I ever wanted to......
kbrennan007@hotmail.com
Have a good one
08-02-2005, 07:04 AM
1966 22' Safari
1979 30' Argosy
Armada
, Michigan
Isn't 80 amps a bit of overkill? What was the rationale for it? Did you add up the power you would use and then work it from there?
08-02-2005, 08:36 AM
1999 34' Limited
1962 19' Globetrotter
Northern
Steve,
Looks like you're getting lots of help on this one. I think the black looking pump is actually the vent dan for your bathroom. The switch to turn it off and on is a small button looking affair on the closet wall next to your toilet.The red valves are for winterizing. Open to drain for winter close for use. You also have 2 more under your kitchen sink. I just instaled the Intellipower converter and am very happy with it. The install went well and Randy at Bestconverters.com was helpful when I called with a question. The price was under $200.00 and the shipping was free.
08-02-2005, 12:10 PM
1972 25' Tradewind
Lake Worth
AYRSTREM2... well kinda. I added everything up and even with the the 200w 4-channel amp crancked, every light,fan on I'm still only pulling under 60amps. So my thinking was that if I can use 50-60amps then why not go over that amount. You are right, it is alittle over kill, but so is everything I did. All the wires are changed to marine grade, all connections are soldiered and heat shield wrapped. I changed out all fuses to new “Maxi” automotive type. 100amp/12vDC Distribution panel. Like Tim the tool man would say... AARRR AARRR AARRR AARRR..........
Kidding aside, using a 80amp unit would alow me to draw all the power from it and still be able to charge the batterys. If I had a 40amp unit and was using 50amp worth of power I'd not be able to recharge the battery's at the same time. I'd actualy be still drawing from them. And back to the joke... I'll probably never ever need to do the both. BUT.... MORE POWER, MORE POWER
08-02-2005, 11:18 PM
1976 31' Sovereign
1961 19' Globetrotter
Phoenix
TEll ME MORE, TELL ME MORE....
I started gutting our new '76 over the past weekend, I want to do everything you've done to yours (wireless, MP3, surround etc.). When I plugged her in the first time, that strange buzzing sound echoed throughout the coach. Assuming this isnt a healthy sound for a 30 year old, its time for modernization. So I'm just starting out as well. Plus the wife digs your leopard coach.. Any words of wisdom would be helpful....
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Univolt FACTS
smily |
69 |
08-18-2005 11:47 PM |
1981 Airstream Excella Univolt
dienst1 |
Airstream Motorhome Forums |
1 |
08-20-2002 09:05 AM |
Bad Univolt?
pebblepoint |
1 |
07-14-2002 10:08 PM |
univolt III wiring
McGill |
0 |
07-05-2002 08:26 PM |
Univolt Operation
melprice |
11 |
06-17-2002 04:13 PM |
