We have a 2017 FC 25 and have horrible interference on both of our TV pictures when using the mushroom antenna. We do not have any problems when using our DISH Navigator sat signal so it's not the TV.
At times, we've been able to worsen the problem by cranking the LED ceiling lights and also able to reduce (but not eliminate) by dimming or turning the lights off. We are also able to create the problem by running the shower fan.
I've searched the forums and others have experienced the same problem but it doesn't appear to be widespread based on the limited posts I've found. Or maybe it's limited to 2016 & 2017? I don't know but I do know it isn't acceptable. Here's an example
http://www.airforums.com/forums/f44/...ms-157711.html
So does anyone have a 2016 or 2017 that doesn't have TV interference when using the digital antenna?
