Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 12-04-2019, 12:10 PM   #21
van guru
1994 28' Excella
Hood River , Oregon
If you replace the wires going from the roof into the trailer then you might want to consider 10 or even 8 gauge. This will reduce voltage drop losses and allow you to add more panels later.
https://www.amazon.com/WindyNation-E.../dp/B01L6OU5TE
If you need to connect 2 panels in parallel then these Y-connectors are better than most. https://www.amazon.com/gp/product/B07NJDZZZ1
All the best,
Hein
DIYvan
Hood River, OR
541 490 5098
Hein is offline   Reply With Quote
Old 12-05-2019, 06:37 AM   #22
2019 25' International
Atlanta , Georgia
Hey PCMeC, When checking your controller for charging status, are you plugged into shore power and/or is the 7 pin connector from your TW plugged into your trailer? If so, those two situations will override the solar power charging.
1590Denny is offline   Reply With Quote
Old 12-06-2019, 12:00 PM   #23
vanster's Avatar
1967 17' Caravel
Oakland , California
Drive down to Zamp in Bend OR and have them sort it out. They are great to work with
vanster is offline   Reply With Quote
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Troubleshooting dead solar kit controller almcate Generators & Solar Power 3 01-23-2015 06:27 AM
Adding panels on top of panels instead of replacing? The-Marco Ribs, Skins & Rivets 18 08-02-2014 04:53 PM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 07:47 AM
