Old 07-02-2017, 12:35 PM   #1
Sylvie's Avatar
2016 27' Flying Cloud
Portland , Oregon
Tripped GFI
Help! My husband has brain cancer and accidently left the bathroom water running and flooded the grey water tank. The water flowed out of the trailer through the area under the bed in our 2016 Flying Cloud. Everything is working except the plugs in the kitchen area, under the dinette, in the bathroom,and in the bedroom near the floor. Everything else is working. Any ideas on how to get them to work? We tried resetting the GFI and it will not push in at all. Thanks for any help you can provide. I am now the one to try to figure these things out and I'm not very good at it.
Sylvie is offline   Reply With Quote
Old 07-02-2017, 02:31 PM   #2
2007 22' International CCD
Tripped GFI
Moisture in one of the plugs is probably the issue. Check the outlets where water might have run into them.
If they seem wet, disconnect all AC power from the trailer, and shut off your inverter if you have one. Let the outlet dry out completely, then try resetting the GFI after restoring power. If that does not fix it, get knowledgeable help.
Old 07-02-2017, 11:10 PM   #3
Sylvie's Avatar
Portland , Oregon
Thank you!
circuit tripped and will mot normalize FFEJANDIRAB Batteries, Univolts, Converters & Inverters 13 11-22-2015 10:06 AM
Tripped breaker Pat Cassity Lights - Interior & Exterior 2 06-07-2014 06:47 PM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 07:17 PM
A/C Blows GFI in Home Jenturnr Our Community 3 07-27-2004 08:39 PM
Gfi markus Electrical - Systems, Generators, Batteries & Solar 4 01-28-2004 09:23 PM
