Old 08-11-2020, 03:50 PM   #1
2015 27' FB International
Erie , Colorado
Tire Tracker TT600 Signal Booster
I have a 27 FB International Signature and need to install the signal booster for a Tire Tracker TT-600 pressure monitoring system. The booster needs to connect to 12V source (+ and -) and should not be outside as it is really not waterproof. I am wondering if anyone else has installed the booster and if so where and to what 12v power supply?
Rockhound100
2015 27FB International Signature
2015 RAM 2500 6.7 TD
Rockhound100 is offline   Reply With Quote
Old 08-11-2020, 08:54 PM   #2
StuartsDad's Avatar
2018 28' Flying Cloud
Fairfield , California
I mounted my booster and a on/off toggle switch to a junction box, then mounted the box inside the propane tank cover to the lid hinge brace. Routed power wires out bottom of tank cover to battery box with an inline quick disconnect when tank cover has to be removed. Clean install,IMO, and protected from weather. Thought I had pictures, but must have removed from phone. Bringing my AS home from storage tomorrow if more details or pics desired.
StuartsDad is offline   Reply With Quote
Old 08-11-2020, 10:54 PM   #3
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
I have a 25' front bed queen. I installed the signal booster at the top of the front curb side wing window, which gives the signal booster line of sight contact with the pick up cab. The window glass has a plastic moulding which is secured by screws--attached the signal booster using one of the existing screws.
On my trailer the tool compartment is on the curb side under the queen bed. I bought a rocker switch with an 8' prewired lead on Amazon for a few bucks, and robbed power from the 12 volt supply to the tool compartment light.
I installed the switch on the tool compartment wall to the right and above the tool compartment door--an out of the way position where the switch won't get bumped accidentally.
When I hitch up I turn on the switch. The signal booster has a bright green LED light to indicate power on, which is visible from the outside.
While I had hoped locating the switch in the compartment where I store my hitch accessories would make things easy, I see that blinkety blank LED light when I crawl into bed. Maybe you'll have better luck remembering to turn the switch off upon arriving at your destination!!
Otherwise, the signal booster works great and is fully protected from the weather. Its the operator that's the problem.
Burnside Bob
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
WeBoost Cellular Signal Booster grwalk Airstream Classifieds 2 11-13-2019 06:02 PM
weBoost Drive Sleek (Cell Phone Signal Booster) TayaraTravel Sprinter and B-van Forum 45 11-28-2018 02:38 PM
For Digital TV Signal, is Antenna Booster necessary? cmkirkland Audio, Video & TV 12 04-09-2010 01:45 PM
tv signal booster joel Electrical - Systems, Generators, Batteries & Solar 4 08-23-2006 11:05 PM
