Old 12-07-2017, 09:32 AM   #101
Mollysdad's Avatar
Originally Posted by gypsydad View Post
"Any comments on the Knife top mount disconnect switch? I used on my 25' for 3 years and never had any issues. I just got this one and am about to install in my 28'. Thoughts?"
I'm sure it will work fine, keep the contacts clean.
The caution of a knife switch is all the exposed metal if you use it on the + side. It's very easy to touch it with a wrench and cause a short.
BTW, while watching a YouTube video from Patrick (superb), he mentioned that you need to keep the "Store" switch in "Use" while trailering or else the batteries won't charge from the umbilical. True?
Old 12-07-2017, 09:57 AM   #102
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Update
Made this update on other similar posts, so hope your not saturated...
1) My friends 2017 23D update- Interstate verified the new batteries they installed few months ago were fine. AS Fairfield guys detected bad Converter on his AS; they determined it was always on while on shore power, but not charging batteries. They replaced stock single stage converter with a new Progressive Dynamics PD4600 series multi-stage converter. Everything working well. Just out the cost of the new Converter. Working with AS to see about warranty refund to apply toward the PD4600...stay tuned.
2) Installed the battery disconnect knife switch in my unit. When I throw this to off position, now power to AS. No more guessing on whether the AS is drawing power in stor. Pictures below.
Name:	battery disconnect off.jpg
ID:	300525   Click image for larger version
Name:	battery disconnect switch on.jpg
2017 28' Twin Flying Cloud
Old 12-07-2017, 11:59 AM   #103
PKI
PKI's Avatar
Walnut Creek , California
GD - you have asked for input on the knife switch solution. If it is rated for the maximum amp flow, it is a way to provide power and to remove that current flow to eliminate parasitic flow. Worth doing.
The problem I have with the knife is that it is an uncovered/uninsulated source of power. Most safety recomendations direct the insulation of battery power with covers. How the batteries or the cover would come adrift and allow the knife to short is difficult to forecast, but better isolation seems prudent.
The knife is a quick and easy solution to disconnect the power and eliminate parasitic loads. To improve the install, a layer of insulating tape or a thin plate of insulating material might be attached to the cover. Should be rather easy to add. Certainly other solutions could provide the same protection. A cover over the knife might also protect againt a short from dropping a tool.
The turn type switch isolates the power connection, but is more complex to install. Consequently, the decision may well depend on the individuals personal preferance, skills or budget. The multiple position turn type switch that allows none, one or both coach feeds to be connected seems the best option, given the installation ability or budget to pay for one.
Something that removes parasitic load should be practiced. If nothing else, remove the battery cables. Pat
Old 12-08-2017, 03:34 PM   #104
gypsydad's Avatar
Multi position switch was also attractive option; as you mention, not straight forward to install for everyone...I used this type for several years on my 25'AS's, and no issues. Good suggestion on the insulating tape as a precaution...I have considered this also. There is plenty more clearance in this battery box then on older models to isolate better, if desired.
Old 12-23-2017, 02:42 PM   #105
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Turn style disconnect
Also concerned about any large metallic battery disconnect apparatice and learned of these simple low profile In the battery box “direct mounted turn style”. Rated up to 200amp constant load. Placed on negative but works on Pos. Quarter turn for on -off. Works great! $10.95 Amazon Prime.
2. No more drain from the AS when storing.
3. When in disconnect, can quick clip to external “extra smart” lightweight Potec 2,5,10 amp selectable rate charger /reconditioner without ratcheting disconnection of battery lugs.
4. Allows for easy accurate inline current measurment load tests figuring what’s killing the dang batts so fast boon docking !
ID:	301324   Click image for larger version
ID:	301327   Click image for larger version
Vantair is offline   Reply With Quote
Solar charge batteries in "store" mode? Zybane Electrical - Systems, Generators, Batteries & Solar 3 05-26-2016 11:35 PM
Do you tow in "use" or "store"? xo1rider 2011 - 2015 International 17 11-06-2011 09:20 AM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
Are you viewing in "full screen" mode? Rog0525 Forum Admin, News and Member Account Info 4 04-03-2004 10:39 AM
