RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-19-2020, 10:36 AM   #21
2018 22' Sport
Healdsburg , California
Very very informative. I've been looking at the Magnum 3000W hybrid inverter as a replacement for my WFCO 1000W inverter. I've two Experion360 lithiums totaling 240Ah and will, someday, get another one or two for the same reasons discussed in this thread. e.g. AC in midday in Arizona summer while parked for lunch on the road. I'd appreciate comments comparing the Magnum hybrid inverter to the Victron 3000Watts MultiPlus inverter. Price would probably be once big point.
lilboomer is offline   Reply With Quote
Old 02-19-2020, 11:18 AM   #22
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Hello and thanks for the kind words.
Both the Victron and Magnum are great inverters. I’ve been primarily using the Victron MultiPlus because it ties in well with the other Victron components. I have both and they both work flawlessly. I guess it just depends on which path you go down.
The Victron can be had for around $300 less than the Magnum
Ronnie
Old 02-19-2020, 10:31 PM   #23
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
Lady Lake , Florida
‘Tis Daaaaa System
Nice job 👍 I
You know I want it! Lol. Saving to afford it.
Life is a Highway is offline   Reply With Quote
Old 02-19-2020, 10:33 PM   #24
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by Life is a Highway View Post
Nice job 👍 I
We will be here when ready....
Old 02-19-2020, 11:20 PM   #25
2016 30' International
redondo beach , California
Originally Posted by GMFL View Post
Yes, switch will disconnect the panels from the system and the breaker fuses the solar charger to the batteries. The switch is used to remove solar panel output from the system including the solar controller for service and the breaker protect the batteries from a fault in the solar controller
The MPPT controller has a service mode setting.
Nice project, LiFePO4 are the best!
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 02-20-2020, 06:41 AM   #26
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
We will finish this project today. Adding the panels to the roof and wiring them into. The system.
Only thing that will be left will be the Maxim Skylight, an Awning light, and add a propane quick disconnect for a generator/grill.
Old 02-20-2020, 01:29 PM   #27
Bacliff , TX
The cut-off switch is generally located a convenient place so that it you can turn off the incoming pv voltage before disconnecting the battery. Remember to always cut-off PV power before disconnecting the batteries or you may blow out the solar charge controller.
jimdelane is offline   Reply With Quote
Old 02-20-2020, 08:21 PM   #28
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Finished!
Got this project buttoned up today. All neatly tucking under the front couch.
ID:	361454   Click image for larger version
ID:	361456   Click image for larger version
ID:	361458   Click image for larger version
ID:	361460   Click image for larger version
ID:	361462   Click image for larger version
Old 02-20-2020, 09:34 PM   #29
Portland , Oregon
Ronnie,
Well done. Congrats!!
Cheers,
Bryan
blacklab is offline   Reply With Quote
Old 02-22-2020, 06:25 AM   #30
The MPPT solar controller has a service mode that turns off power to the batteries. You don't need a switch.
Old 02-22-2020, 06:37 AM   #31
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
But you do need a fuse/breaker between the batteries and controller.
Old 02-22-2020, 04:04 PM   #32
True that.
Old 02-23-2020, 08:49 AM   #33
2019 22' Sport
Carlsbad , California
True that.
What amp rated fuse should you put between the controller and battery? How many amps above the controllers output? I just had a Victron SmartSolar 100/20 installed
Prettygood is offline   Reply With Quote
Old 02-23-2020, 09:40 AM   #34
Half a Rivet Short
Carlisle , Pennsylvania
Hi
With the Multi Plus, you can run in both charge (off the shore power) and discharge (running the inverter ) modes. The power draw in inverter mode will be way above that in charge mode ( = that is what sets the fuse size and wire gauge).
With just a solar charger, the fuses and wire need to handle the max output of the changer. Most manufacturers will mention the appropriate fuse in their install information. In their manual Victron suggests a 25A fuse for the 100/20.
Old 02-23-2020, 09:59 AM   #35
2019 22' Sport
Hi
I must have read right past that, thanks
Old 02-28-2020, 10:33 PM   #36
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Rule of thumb is 125% of the rated output.
Example.... 100/30m= 40A fuse 100/50 =60Afuse.
Frank’s lithium battery and inverter upgrade fran&frank Batteries, Univolts, Converters & Inverters 85 09-04-2018 10:51 PM
New Lithium Battery / Inverter Install Rawn77 Batteries, Univolts, Converters & Inverters 19 05-11-2017 09:53 PM
Replace stock inverter when going to lithium? fran&frank Batteries, Univolts, Converters & Inverters 5 12-12-2016 11:36 PM
