RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 03-11-2019, 06:14 PM   #1
2019 16' Sport
St. Louis , Missouri
Split Charging
I have been trying to learn about split charging, but still don’t believe I have it figured out so any advice would be appreciated. Thank you in advance!
I have a heavy duty alternator with my tow package for my TV and two 6v in series on my AS Sport 16’.
What I’d also like to do is have a leisure battery in my truck bed to run some accessories when we are at a site.
Questions:
1. Can I simply run a split charger between the starter battery and leisure battery?
2. Would this adversely affect the AS batteries charging from the TV at the hitch?
3. Am I correct that the TV can handle charging the AS 6v batteries and leisure battery while driving?
I have thought of even just mounting a flexible solar panel to the truck to charge the leisure battery and eliminate the idea of split charging.
BTW when we’re boondocking, i have a Renogy 100w portable that does fine for now.
Marcos
Grateful26 is offline   Reply With Quote
Old 03-12-2019, 08:01 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 🥂👍
My experience...I learned that the TV alternator is the least effective way to charge the AS batteries.
I have never used 6v, Two Interstates 3yrs> 2 Lifeline AGM's 11yrs> 2 Lithiums 1yr.
Even the 200a in our Suburban is marginal at best.
FWIW...we used a 1000w Yamaha genset to keep everything charged in our first AS...23' '63' Safari.
“It’s not the system thats the problem, think Circus, it’s not the car, it’s that the car is full of Clowns.”
John Turley
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 03-12-2019, 08:37 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have used a leisure battery (your terminology) for years.
Charge it with a solar panel or generator depending on circumstances.
My coach only has room for 1 battery. I mounted a 7 pin connector in the side of the coach. Wired only the charge line terminal and common/ground in parallel with the house battery.
This gives me the option of connecting the solar panel to charge the house battery or connecting the leisure battery in parallel with the house battery.
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 09:12 PM
Split Rim Or Not? Jabba Wheels, Hubs & Bearings 3 11-11-2002 08:43 AM
Opps... (Split thread problem) Andy R Our Community 1 10-19-2002 03:12 AM
