Old 10-17-2021, 10:53 AM   #21
2000 19' Bambi
BOZEMAN , Montana
We remove our batteries and store them in a semi-heated garage during winter hibernation. AGM and flooded batteries are stored fully charged and topped off every couple of months. The camper's lithium battery is discharged to 60% prior to storage and not fully charged until it is re-installed in April or May.
It's my understanding that unnecessary cycling of lithium batteries can shorten their life span. Also, the lithium battery's minimum charging temperature is listed as 32deg F.
BobBozeman is offline   Reply With Quote
Old 10-18-2021, 09:44 AM   #22
Bacliff , TX
If you plan to store in sub-freezing temps, purchase a lithium battery with low temp charge protection. It has pretty much become a standard feature. They do not cost that much more. As pointed out, you can protect your lithium batteries from charging below freezing with solar by setting a temp charge cut-off point with some solar controllers. I am not sure about onboard converter/inverter chargers....
BattleBorn has a heated battery which you pay a premium for and uses battery power to keep warm. Other considerations is a well insulated battery box and 12v heat pad.
jimdelane is offline   Reply With Quote
Old 10-19-2021, 08:34 AM   #23
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Just to clarify a bit:
The heated batteries should only be heated when charging. Otherwise the heaters should be turned off. They will use a lot of battery power if you just let them run for a day or three.
Old 10-19-2021, 08:45 AM   #24
2019 22' Sport
Hi
I'd remove terminals from battery for storage it's easy.
Sean
Kanusport is offline   Reply With Quote
Solar panel connection in addition or in place of Rooftop solar panels? D Shauberger Base Camp 42 05-07-2022 12:23 PM
Winter Living and Solar Panels stevejones Winter Living 15 10-24-2018 09:08 AM
Startup Voltage for Solar Charger and 12v solar panels ggreen63304 Generators & Solar Power 12 09-01-2017 06:58 PM
Best Quality Solar Panels & Solar Controllers to use | Opinions Wanted BoldAdventure Generators & Solar Power 54 03-17-2016 06:04 AM
Solar Panels and Battery Disconnect Freedomrider Generators & Solar Power 6 12-04-2012 02:51 PM
