Solar install Question for 2016 25' FB Int. Serenity
Has anyone installed the charge controller, breakers etc. under the bed of a 25' front bed? We are planning on 2 AGM batteries and I would like to keep them in the existing battery box. Later if we ever go to 4 batteries. I would probably do a custom box for the same spot or move them to just behind the divider in the main storage compartment under the bed.
The attached picture shows this area. The inverter is there and existing wiring runs out here. I think there is enough room to fit the controller and breakers. My only concern is the length of the run from the controller to the batteries being to long? If this is a good spot where would you pull / run the solar panel run?
Thanks!
