Old 08-06-2019, 11:47 AM   #1
2009 16' DWR
Bozeman , MT
Solar Hookup
I am a recent owner of a 2009 bambi DWR. The manual indicates that the 16' models were not equipped with the yellow and green wires for solar connection, however I see those wires labeled "solar" under the front road side dinette. My question is would I hood a external solar port for a portable panel directly to these wires. As an alternate would I hood a solar controller to these wires which I assume are a direct link to the battery. Has anyone had experience doing this. Thanks in advance.
Logan225 is offline   Reply With Quote
Old 08-06-2019, 01:43 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I have not seen a DWR model, but on other trailers, the green and yellow wires go up to the roof. They are intended to connect rooftop solar panels to a solar controller. You found the end that would be connected to the controller.
These wires will not be of any use for hooking up portable solar panels.
SSquared is offline   Reply With Quote
Old 08-06-2019, 06:15 PM   #3
"Cloudsplitter"
Welcome aboard...👍
I made an adaptor and connect two Zamp 180w portable🌞 panels to the 7pin umbilical, simple & effective.👍
ID:	348704   Click image for larger version
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Double solar system hookup. AWCHIEF Generators & Solar Power 58 02-10-2016 08:46 PM
Outside water hookup question. 68 Suburban Fresh Water Systems 6 10-05-2013 02:25 PM
Solar panel to AS battery hookup question txstreamer Generators & Solar Power 12 04-25-2011 03:32 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
Hose for gray water to sewer hookup?? eikel1we Waste Systems, Tanks & Totes 12 03-11-2003 01:49 PM
