RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 04-29-2018, 02:30 PM   #1
Viewseeker's Avatar
2018 25' Flying Cloud
Aurora , Colorado
Solar Charge with Master Off
Brand new owner with factory 160W solar. 2018 FC 25RB.
Expecting the solar to keep the batteries topped off while AS is in storage.
Question. With the inside master power disconnect switched off, do the solar panels continue to charge the batteries?
Viewseeker is offline   Reply With Quote
Old 04-29-2018, 03:53 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
If they do not currently they can, by hooking the (+) pos lead from solar to the battery side of the Solenoid the panels will charge.
Old 04-29-2018, 06:18 PM   #3
Journeyman
2016 25' International
Deerfield , Massachusetts
Wait...does the top vs bottom side of that copper buss thingy make a difference?
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 04-30-2018, 06:17 AM   #4
"Hey, I know you!"
Boog's Avatar
Chapin , South Carolina
Mine has fuses hiding underneath and the copper half is conductor and the silver half is the fused side. Actually, the copper part is protected by a 50 amp fuse from the battery in. Here's an approximation of what mine looks like:
Boog is offline   Reply With Quote
Old 04-30-2018, 06:44 AM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Yes it does. As Boog stated. The copper side is fused by a auto reset fuse on the back side.
Note photo of mine. Copper pin on the Right is line. 12(+) DC power coming in.
This provides power to the copper bus bar. Then the copper bus bar distributes power to the other fused circuits.
Old 04-30-2018, 07:24 AM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I need to make a correction to my first post. You would need to connect the (+) pos lead from the solar controller not the yellow wire from the solar panels
Old 04-30-2018, 08:02 AM   #7
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Does it matter which side?
I've seen it connected both ways:
- On Copper pin here: https://currentlywandering.com/2015/...he-wire-panel/
- On Nickle pin here: http://www.airforums.com/forums/f448...tml#post439984
Airstream's Solar Wiring diagram also flip flops on which pin to use:
-The 2015 Airstream Owner's Manual recommends connecting to the copper pin: http://www.airforums.com/forums/f448...tml#post439981
- My 2017 Airstream Owner's Manual's Solar Wiring diagram recommends connecting to the nickle pin.
It appears connecting to either will work, but is one the preferred method?
Would connecting a fused line from the solar controller output to the copper pin result in less resistance?
2021 Northern-Lite 10-2 & F350 DRW PSD, 380W Solar/Victron/600A BattleBorn
0 nights 0 miles
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 04-30-2018, 10:19 AM   #8
2017 25' International
Framingham , Massachusetts
Remember the wiring and master switches were changed in the 2018 models from previous years.
Best place to start? Owners Manual.
quietguy is offline   Reply With Quote
Old 04-30-2018, 10:48 AM   #9
Viewseeker's Avatar
Aurora , Colorado
Thanks all. My electronic wiring skills are pretty limited. but good information.
Heading to owners manual to see what it says (should have started there but like getting the forum expertise involved).
Old 04-30-2018, 01:59 PM   #10
1985 31' Excella
st. Paul , mn
With the apparent lack of knowledge , I would suggest - " brand new " go to a dealer .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 05-09-2018, 08:39 PM   #11
2018 Basecamp
Northern California , California
According to my owner's manual for a 2018 Basecamp with factory installed solar panels, the solar panels continue to charge the battery even with the master power switch turned off . . . unless it's indoor storage.
swakyaby is offline   Reply With Quote
Old 05-10-2018, 09:20 AM   #12
Viewseeker's Avatar
Aurora , Colorado
Thanks for the follow up. My AS is in outdoor storage and when I visited last weekend the batteries were charging and at 100 percents.
Solar charge controller affect charge from converter? fran&frank Electrical - Systems, Generators, Batteries & Solar 1 03-22-2016 11:39 PM
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 09:38 AM
Whats the best Solar Charge Controller? Keyair Generators & Solar Power 17 05-09-2011 06:04 PM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 08:16 PM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 03:04 PM
