RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-31-2020, 01:39 PM   #1
2018 27' International
Irwin , PA
Solar and removing batteries
I am planning on removing the batteries to store them inside for the winter. Do I need to doing anything with the factory installed solar?
mtnhike51 is offline   Reply With Quote
Old 01-31-2020, 01:52 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
I did the same this year.
Just remember the solar panels can generate power and send it back to the battery cables. Two options - disconnect the panels at the combiner box on the roof or cover the positive cables with a piece of foam pipe insulation or similar insulator. *Always take the negative cable off first and put in on last.
PS: Welcome to the forum and Airstream community!
2019 27 Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-31-2020, 02:03 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard...👍
No...just clean them well in the Spring.👍
FWIW...when we first got our Classic I also took the batt's out every winter kept them in the basement. Replaced with Lifeline AGM's, great battery but heavy, a pain to remove from the Classic compartment...taking out for Winter lasted about 2 more Winters, from then on it was charge fully, disconnect and leave them where they are, they lasted 11 seasons.
The BattleBorn Lithiums stay in, connected, with interior disconnect switch engaged. Unless working in the trailer or testing the system. They do have a built in management system for low & high temp protection, they will not accept a charge below 25*F
Its not the system thats the problem, think Circus, its not the car, its that the car is full of Clowns.
John Turley
Tahawus
Old 01-31-2020, 03:05 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i remove my lion battery
i install a disconnect for the solar, for winter and to work safely on them in the summer
waninae39 is offline   Reply With Quote
Old 01-31-2020, 03:24 PM   #5
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
On factory solar installations, you can easily unplug the panels from the Zamp Rooftop Box or remove the inline fuse on the wire coming from the solar controller. The rooftop wires unplug in like an electrical cord. The positive side is rubber coated and the negative side is bare copper. Here is a link to a picture of the Zamp Rooftop Box: http://www.airforums.com/forums/f448...ml#post2288584
2021 Northern-Lite 10-2 & F350 DRW PSD, 380W Solar/Victron/600A BattleBorn
0 nights 0 miles
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 02-01-2020, 09:06 AM   #6
Irwin , PA
Thanks for the info.
Old 02-01-2020, 11:52 AM   #7
Irwin , PA
I took batteries out and the tray had some water in it. Will that harm the batteries over time? How do u prevent water from getting into the box?
Old 02-01-2020, 01:47 PM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
No reason to remove them
Don't know the split between those who leave their batteries in the trailer for the winter and those who remove them, but I would guess a fair number just leave them in the trailer.
Batteries which are disconnected and fully charged will do just fine in cold weather. And for those who have solar, then you can disconnect everything except for the solar controller and let the winter sun send a float charge to maintain them 100% charged if you don't have shore power where the trailer is stored.
Given that I don't like to weigh down the trailer's suspension with a season of heavy snow, every few weeks I clear it off, and make sure 1-2 panels are free of snow when they forecast a few days of sunshine. Works for me and I don't have to disconnect my four 6V deep cycle batteries, haul them inside and reconnect them every year.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 02-01-2020, 04:13 PM   #9
Well, you are even further North than we are here in WNY, with possibly an even longer off Season, I concur on the battery choice.
But with the AS's rubber torsion axles I approach long term winter storage differently.
Take the weight off, save the axles & tires.👍
ID:	360357   Click image for larger version
John Turley
Tahawus
Old 02-01-2020, 06:03 PM   #10
Hermes's Avatar
If we lived in Newfoundland, this would be our Airstream...
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 09:34 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 08:18 AM
Removing Batteries with Solar System Airstream 65 Generators & Solar Power 2 11-08-2009 06:39 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
