06-24-2017, 11:10 AM
2020 22' Bambi
Chillicothe
Shutdown
Parked the AS 8 days ago after having some warranty work completed at the Mothership. Excellent service by the way.
Showed the wife the new exhaust fan and she checked it out ... wasn't hooked up to shore power.
This morning I went out and there is no power; even the carbon dioxide alarm is "black".
I start thinking the batteries went dead.
Hook the 30A up to our shore power and everything works of course. Check battery monitor and it reads 13.7. CD alarm starts off blinking red and the after a minute moves to green.
Disconnect shore power and everything that is suppose to be powered is powered. Battery monitor reads 11.7
Reconnect and battery reads 13.3.
Going to check battery water levels. Any thoughts?
06-24-2017, 11:26 AM
Chelsea
, Maine
11.7v is essentially dead. Sounds like your batteries went dead, when you plugged in they charged some, but not completely.
You need a good charge, then see how they act.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
06-24-2017, 11:38 AM
2017 30' International
Broomfield
Shutdown
Agreed batteries are dead.
It's showing 13.7v/13.3v when on 30amp shoreline because that is the voltage your converter/charger is putting out to charge the batteries. The battery voltage monitor in the trailer reads "system" voltage not specifically battery voltage. If you really want to know the state of your batteries you need to install a more sophisticated battery monitoring system like the Victron 702 monitor.
Why were they dead? Without a constant charging source like solar integrated with your energy system if you don't physically disconnect your batteries while in storage or during a service call (remove all negative leads at the battery terminals or use a proper disconnect switch) they will discharge to dead even when the interior "disconnect" switch is engage due to propane leak detector and inverter standby draws, which are hardwired to the battery.
I use a battery disconnect switch that I threw into the battery box and I mechanically disconnect the batteries from all trailer loads when in storage....
06-24-2017, 11:59 AM
2020 22' Bambi
Chillicothe
Hopefully they aren't entirely dead ... I am putting them on my Genius smart charger. Wulfraat where do I find that disconnect switch?
My error also as I didn't use the disconnect switch?!
06-24-2017, 12:10 PM
Long Island
, New York
You should read your owner's manual to locate the Use/Store switch in your model. Most are located just inside the main entry door.
Your batteries are probably not dead, but compromised. If the batteries were new and healthy, a one-time complete discharge will not kill the batteries, as I understand it.
Your plan to charge them for a couple of days is a good start. After charging, disconnect the charger, unplug from shore power, and wait one hour. Then check your battery voltage on the monitor.
Good luck!
PS -- In our 2014 FC20 with original Interstate Group 24 batteries, we can remove shore power, turn to "Store," and our batteries will still read about 12.5 volts after one week, even with the propane detector left online, notwithstanding recent dire comments.
PS2 -- This Battery School article is good background reading IMO:
http://www.batteriesnorthwest.com/batteryschool.cfm
06-24-2017, 12:13 PM
2020 22' Bambi
Chillicothe
Originally Posted by OTRA15
You should read the owner's manual to locate the Use/Store switch in your model. Most are located right inside the main entry door.
Your batteries are probably not dead, but compromised. If the batteries were new and healthy, a complete discharge will not kill the batteries, as I understand it.
Good luck!
I knew better. Self inflicted for sure.
06-24-2017, 12:14 PM
2020 22' Bambi
Chillicothe
What is the name of that disconnect switch?
06-24-2017, 12:22 PM
Long Island
, New York
Happens to everyone sooner or later. BTW my original comment has been edited since you quoted it.
Not the end of the world! Your batteries are probably in better shape than you think. You could take them out and have an Interstate dealer test them, which will give you peace of mind for the camping season.
Happy Trails!
Peter
06-24-2017, 12:55 PM
2000 25' Safari
1999 34' Excella
Davidson County
, NC Highlands County, FL
Blue Seas selector switch
Alan
06-24-2017, 01:33 PM
2020 22' Bambi
Chillicothe
Good luck!
Thanks for the article link. I'm big on read to learn and then applying the skills.
06-24-2017, 01:42 PM
Broomfield
Here is a link to the one I use
https://www.amazon.com/gp/aw/d/B000M...?ie=UTF8&psc=1
Allows me to choose from
Power to trailer
Power to inverter
Power to trailer + inverter
All off
Note that you will need to cut off the automotive clamp on the 6ga trailer lead and replace with a 3/8 bolt through connector.
06-24-2017, 01:50 PM
2020 22' Bambi
Chillicothe
Power to trailer
Power to inverter
All off
Very nice. I'm sold.
06-24-2017, 01:52 PM
2020 22' Bambi
Chillicothe
Happy Trails!
Peter
Curious if you remove your batteries to charge or charge them in parallel in the battery box?
06-24-2017, 01:55 PM
Long Island
, New York
Never charged them with a stand-alone charger. I would remove them, but not sure that is necessary. Seems safer IMO.
06-24-2017, 02:10 PM
Broomfield
Shutdown
Leave your batteries in the box, you can charge them when connected to shore power (the on board converter / charger will charge them when they are connected to the system)
Now comes the debate around the quality of the factory parallax charger installed in your airstream
06-24-2017, 02:52 PM
2020 22' Bambi
Chillicothe
I've been reading those comments haha
06-24-2017, 02:53 PM
2020 22' Bambi
Chillicothe
In for a penny ... I'll throw it out to the group
06-24-2017, 03:03 PM
Broomfield
 yes a slippery slope indeed!
It really comes down to how you use your trailer - mainly plugged in to campground power or extensive off grid camping, which requires better batteries, charging, likely solar, etc etc
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Electrical shutdown
Jdh |
Electrical - Systems, Generators, Batteries & Solar |
0 |
09-12-2014 06:29 PM |
Generator Shutdown
BRIDGESRE |
Generators & Solar Power |
4 |
10-09-2009 05:11 PM |
