Old 07-31-2021, 07:37 AM   #1
2018 25' Flying Cloud
Provo , Utah
Sealing the floor hole where old wires used to run
As part of my lithium battery upgrade, I've removed the old wires from the small battery box on the front of coach. I know some people leave them, but I didn't want "dead" wires to clutter things up.
In my 25 FB Twin, the wires run to the front curb side corner of the coach through a hole in the floor. They were sealed by some sort of pliable black sealant. Now that I've removed a lot of the wires that run through the hole, lots of new space in the hole and it needs to be re-sealed with new sealant.
Does anyone know what type of sealant that is? I can use some sort of silicone sealant, but thought I'd check if anyone knows what would be a good choice.
jranck is offline   Reply With Quote
Old 07-31-2021, 07:41 AM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
Size of hole? Picture?
Alumacoot
ďWe are confronted with insurmountable opportunities.Ē
Dan and Liz is offline   Reply With Quote
Old 07-31-2021, 09:03 AM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I wouldn't over-think it. I would probably cut short dowl segments that mostly fit snug in the holes and use silicon, Goop, or even a latex caulk to hold them in place. The good thing is that nothing will be pushing or pulling on them, so most anything should work fine.
You should probably check them once a year or so just like you would window and roof sealant.
rowiebowie is offline   Reply With Quote
Old 07-31-2021, 09:21 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Wires going through a hole rub on the edge of the hole. That can (eventually) have an impact on the insulation on the wires. The "best" way to handle a hole is with some sort of padding on the edge of the hole. There are lots of ways to do this, in addition to the plastic grommets made for the task ( which you buy a hundred at a time .... what do you do with the other 99? ).
Old 07-31-2021, 11:55 AM   #5
gator.bigfoot's Avatar
KW , Ontario
I like using gland connectors. They are often waterproof and can be fastened in place. If there isn't enough space to put the nut on then you could glue it place with construction adhesive or silicone.
gator.bigfoot is offline   Reply With Quote
Old 08-01-2021, 09:27 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I left the old positive connected and continue to use it to power the jack rather than run a new wire to do the same thing.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 08-01-2021, 09:35 AM   #7
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
This is what I use.
https://www.amazon.ca/AP-Products-01...874724105&th=1
thewarden is offline   Reply With Quote
Old 08-01-2021, 12:17 PM   #8
2019 25' Flying Cloud
North-Central , Florida
Is anybody using one of the spray foam insulations (some of which contain a rodent deterrent) to close up gaps like the OP has?
djbar is offline   Reply With Quote
Old 08-01-2021, 03:28 PM   #9
1994 34' Limited
colebrook , Connecticut
Electrical duct seal
Duct seal is a clay like material which is used to seal electrical connections. It is non hardening, very pliable, easily removed and easly formed. It should be be found in big box stores or electrical supply houses.
I use it to seal elecrrical amd pipe penetrations. It works well in areas inacessable with a caulking gun.I have used it for years and yet to find any penetration by rodents.
malett is offline   Reply With Quote
Old 08-01-2021, 05:29 PM   #10
Provo , Utah
Spray foam (the expanding stuff) does well indoors, but not exposed to the elements, at least in my experience. I wouldn't use it where it is exposed outside.
Old 08-01-2021, 05:30 PM   #11
Provo , Utah
Originally Posted by thewarden View Post
I'll probably use this. Thanks!
Old 08-01-2021, 08:18 PM   #12
2021 25' Globetrotter
Oviedo , Florida
Iíve used it in my previous RVs to seal up the huge holes left during manufacture. I know it worked for at least 3 years in my motor home.
jondrew55 is offline   Reply With Quote
Old 08-03-2021, 10:33 PM   #13
2014 25' FB International
Sacramento , California
Can you send me photo's of the battery relocation process. I am considering installing lithium batteries under the bed. Also can you provide schematic for the wiring if possible.
dmartinez is offline   Reply With Quote
Old 08-04-2021, 06:30 AM   #14
Provo , Utah
It may take me a few days, but I'll PM you modified schematics and some photos.
Wanted: Blue Ox 9-hole or 11-hole shank Runamuk13 Hitches, Couplers & Balls 1 12-15-2020 01:18 PM
Sealing Hole in Floor Ronyx Repairing/Replacing Floor &/or Frame 17 01-02-2019 04:43 PM
What is the best way to seal the hole for the wires (battery and 7pin)? Lgebhardt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 06-07-2018 07:55 AM
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 04:10 PM
Sealing hole in floor in 26u Bgibbs General Repair Forum 20 08-29-2016 07:09 AM
