Old 03-25-2023, 07:38 AM   #1
2019 27' Globetrotter
CARY , NC
Sea Level Monitor not working
We took our Globetrotter out of storage yesterday and have discovered that the Sea Level Monitor II isn't getting power. We are hooked up to 30AMP service at the house. Everything else is working. Any thoughts would be great.
We have a 2019 Globetrotter FBT
Todd G is offline   Reply With Quote
Old 03-25-2023, 06:41 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your SeeLevel instruction manual has some diagnostic tests that may be helpful. SeeLevel likes direct lines from the battery positive and battery negative to help resist noise in the instrument. Test to ensure you have 12v at the instrument connector at the back of the instrument.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 03-25-2023, 06:54 PM   #3
2002 19' Bambi
Lafayette , California
Our SeeLevel control panel has an inline fuse. Perhaps yours does, too.
Tim
Tim A. is online now   Reply With Quote
Old 03-25-2023, 09:56 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Get in touch with Garnett Industries, they will walk you through diagnostics, they will probably just send you a new one if it’s toast. Its a good company who stands behind their product.
- Stewart
s1000pre is offline   Reply With Quote
Old 03-26-2023, 05:56 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I agree with s1000pre: Garnet was easy to work with and very helpful to me. I had a erratic and fluttering readout once. It turned out to be an old converter that was sending a bad 12v DC current. A modern converter fixed the problem.
David
Old 03-28-2023, 10:52 AM   #6
CARY , NC
All, Thanks for your suggestions. I spoke to Garnett yesterday and they instructed me to power down the coach for 30 minutes to reset the device. It worked!!!
Old 03-28-2023, 06:47 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good deal. Thanks for the update. David
Old 03-29-2023, 06:00 AM   #8
2019 25' International
Providence , Senior Electrical Engineer
But the real question is why and how did it get into that state in the first place.
It is an embedded device running on a DC source, it should be fairly bullet proof.
If it does it again, I would suspect issues on the boards like a faulty capacitor or some component nearing its end of life for whatever reason.
This is one of those things that you don't want a flaky device monitoring, way to much at risk if the device is "wrong" or locked up.
Sounds like the company will stand by it, so that is a good thing.
kittmaster is offline   Reply With Quote
Old 03-30-2023, 04:01 PM   #9
CARY , NC
We think when we powered up the coach from storage the store switch was stuck so we had to cycle it about 5-6 times to get the power to stay on. That sort of caused the Sea Level Monitor to get hung up. I called Garnet and they instructed me to power down the coach for 30 minutes. Once I powered it back on the monitor woke up.
Sea Level II - Fresh water tank stuck on 100%, even when empty Troutboy Fresh Water Systems 12 01-31-2021 12:40 PM
Sea Level 2 Pthorpe4080 Electrical - Systems, Generators, Batteries & Solar 1 05-01-2018 07:40 AM
Sea level II Monitor Rockhound100 Plumbing - Systems & Fixtures 6 07-08-2017 08:17 AM
Sea Level to High Elevation: Look Out! Ray Eklund On The Road... 21 09-15-2016 10:15 PM
sea level II Drplate General Repair Forum 0 11-09-2015 08:02 PM
