RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-08-2019, 04:52 AM   #1
2018 30' Flying Cloud
New Hudson , Michigan
Running wires through refrigerator vent...
Has anyone had any luck running wires through the fridge vent cover on the roof of a newer model airstream w/o removing the cover? I was able to get the wire through the mesh screen underneath it, but have had no success in getting it to drop down back behind the refrigerator to come out at the bottom vent.. Spent about 2 hours playing with it, even have a small camera in the but can't quite see how to get it down there... TIA.
ekbruster is offline   Reply With Quote
Old 08-08-2019, 06:46 AM   #2
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
I didn't have any luck and instead drilled a hole in the gray water vent right next to the refrigerator vent in my model.
Drilled a hole in the side, then another hole in the side six or eight inches lower in the closet the vent runs through. Fished my WeBoost cable through and installed the WeBoost amplifier in the closet powered by the closet light wiring. Caulked the top and bottom hole around the cable.
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 08-08-2019, 10:13 AM   #3
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I’m getting ready to run the solar wiring behind the refrigerator and through the cover. I expect I’ll have to pull the refrigerator out.
sheriff1 is offline   Reply With Quote
Old 08-08-2019, 12:24 PM   #4
dznf0g's Avatar
Oswego , Illinois
I did it without fridge removal. Use a stiff wire fish tape, drill a hole in the side of the vent curb, which will accept the fridge combiner box. Fish to the SIDE of the fridge. Once fish wire appears down below, affix your heavy gauge (stranded marine) wire to the end of the fish tape and pull it up and out the hole in the vent curb.
Be sure to manipulate the solar wire away from the fridge chimney.
-Rich-
Old 08-09-2019, 11:37 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We ran the wires associated with our nine 100 watt solar panels down from the roof through the refrigerator vent on our 2014 31' Classic. Was easier with refrigerator out to place the solar panel disconnect switch by the refrigerator vent/access door.
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 08-09-2019, 12:51 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Removing the refrigerator is not a difficult task if you make a temporary table/box that is the same height as the bottom of the refrigerator. You can slide the reefer onto the support (one person task) after disconnecting the gas & electrical, and removing a few bolts & screws. This will give you full access to the cabinet interior.
I highly recommend this approach as it allows you to secure the wires to the walls and prevent loose wires from rubbing against any of the refrigerator parts while underway. The chimney is hot and the fin edges sharp, all of which can compromise the circuitry.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-09-2019, 01:27 PM   #7
1993 25' Excella
Scenic , Arizona
Cheap fishtape
If you need a really good and safe (non conductive) fish tape , next time you see someone installing fiber , ask if you can have a length of the strain relief fiberglass core when they strip the fiber jacket off and land the fibers.
dieppe9 is offline   Reply With Quote
Old 08-09-2019, 02:21 PM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Running solar cables from combiner box to controller
Here are the steps we followed to run wires from the Am Solar combiner box to our solar controller (in front, under the L couch) :
1- Order Olympic rivets to replace refrigerator vent rain cover rivets;
2- Drill refrigerator vent rain cover rivets and remove cover;
3- Remove wire mesh covering the refrigerator vent;
4- Drill two ˝” holes in the side wall of the refrigerator vent facing (close to) the combiner box and install two liquid strain reliefs (Am Solar) for battery type cables;
5- Drop a solid string with a weight in the bottom right corner of the refrigerator vent when you are facing the vent with your back to the street (useful to have someone check for the arrival of the string and weight—in my case it worked on first try);
6- Drill a hole in the floor of the refrigerator access compartment (behind the fridge) to pass the string through the hole and pull it to front of trailer where the solar controller is situated;
7- With the string solidly attached, pull two battery type cables (4, 6, or 8 gauge depending on wattage to be carried) from the front of the trailer (where the solar controller is situated), under the counter and stove and trough the bottom of the refrigerator access compartment (see 6) and up the vent;
8- Pass each of the cables through their liquid strain relief in the side of the refrigerator vent wall (see 4);
9- Then pass each cable through a liquid strain relief in the combiner box, to connect them to one of the two bus bars (+ and -) thus linking them to all the connected solar panels;
10- Finally, at the other end, connect the cables to a disconnect switch (+ cable) and to the solar controller (and properly reinstall vent mesh and rain cover).
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 08-09-2019, 04:53 PM   #9
Yeah, so the nightmare is over. I was able to get a loop of the cable show over the side of the fridge, after about two hours fishing it down I got the coax end to fall, but when I went to pull it, it got lodged into the refrigerator fins and stuck, couldn't move it either way, so 6 screws later, a few plates, a 12v and gas line disconnect the fridge came out, and I was able to get it fished down where I wanted it... so NOTE TO ALL those out there, as easy as it may seem to not remove the fridge, save yourself the time (and headache) and just remove the damn thing... I pulled it out and set it on a crate, wired it up, and threw it back in. Thanks for all the insight guys, sometimes the shortest route isn't the easiest..
Rain leak through refrigerator vent 2012 Sport d_logiudice Repairing/Replacing Floor &/or Frame 8 08-02-2020 03:11 PM
How to get cable in through refrigerator vent The Colonel Computers, Internet & Satellite 23 04-16-2017 07:41 PM
Wires/Power for stove vent & roof vent. Jeepers! 1956 - 1965 Caravel 3 10-03-2014 10:21 PM
Running 12 volt wire through refrigerator vent wolverine Electrical - Systems, Generators, Batteries & Solar 5 01-19-2013 11:35 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 10:06 PM
