Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-17-2020, 06:49 AM   #1
2004 30' Classic
California , MD
Running Wire from front to very back?
Good Morning Team,
I need (well "want") to run two #12 and two #16 pairs of wire from the front of the trailer to the rear (for power stabilizers and underbelly lighting to facilitate night time setup). So this would be a long wire run along the underbelly. About 20 feet.
On past trailers (big white box ones), I have simply run wire in a flexible conduit and fastened the conduit to the exposed underbelly frame.
I would appreciate your thoughts on how to do this on an Airstream.
Dan
Classic 30
2004 30' Airstream Classic
cru-in is offline   Reply With Quote
Old 05-17-2020, 06:55 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
I have always tried to hide wires as best I can. (I kinda a wire management Nazi). Anyway.
Option #1 would be to chase them inside the rig under the cabinets shower ect...
If that’s not and option due to bed layout or something else. Then
Option #2 is to drop part of the bellypan and run them inside there.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 05-17-2020, 07:59 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
Dan, I would do as GMFL has suggested. If you can't run it inside the coach then drop some of the belly pan and run it in flex conduit and attach to the frame rails. It is possible to run the flex on the outside of the belly pan next to the propane lines. BUT, if you ever want/have to remove the belly pan later it could be more difficult.
-Dennis
batman is offline   Reply With Quote
Old 05-17-2020, 08:00 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Alternatively, there is already stuff under there like propane piping and so on. When I ran some wires underneath, I put them in a small cable sheath and zip tied that up to existing attachments. It gave me no trouble for the years I had it there(is was for a Garmin license plate camera).
Larry
lsbrodsky is offline   Reply With Quote
Old 05-17-2020, 11:14 AM   #5
2005 28' International CCD
Camarillo , California
Running wires
Don’t put the power stabilizers on the rig. They are slow and expensive. Buy an impact wrench to put the manual stabilizers up & down.
If you start the light wiring in front you don’t need wiring in back do you?
loft47 is offline   Reply With Quote
Old 05-17-2020, 11:46 AM   #6
1976 31' Sovereign
Oswego , Illinois
IMO never use impact wrench on stabilizers as can exert to much down force causing damage. Use cordless 3/8 drill to lower stabilizers, if hard to lower lube them.
Old 05-17-2020, 01:27 PM   #7
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Order some marine of trailer wire (2, 2 strand, or one 4 strand) in a jacket, then simply zip-tie it to the propane lines. Easy peasy
bibbs is offline   Reply With Quote
Old 05-17-2020, 02:10 PM   #8
1988 32' Excella
Robbinsville , New Jersey
This is what I do. Impact driver can also be a bit to noisy for early morning departures.
For wires for lights I would run them from compartment lights.
Old 05-17-2020, 08:57 PM   #9
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
When I had my solar, Lithium and inverter system installed we ran wires every where, but none are now visble. There are all sorts of open areas down the frame, through the crossmembers and in the frame. Also behind kick panels, under, in and behind cabinets. If you use the roof refer vent to bring wires inside and down to the frame you can hide a lot of wires. We added solar and inverter controller pigtails, cel booster, refer fan x 2 and emergency battery disconnect.
guskmg
Old 05-24-2020, 09:19 AM   #10
Box secion frame is a possibility
On my Excella 25 the side frame members are box sections open at the rear end. They are clear of obstruction throughout the length of the trailer. I used some long thin bamboos taped together to pass a remote spray head and hose from the rear and coat the inside of the box section with anti-rust liquid from a compressor. I designed a tiny trolley to carry the nozzle in the center of the box section.You may be able to adapt this method to pass a wire most of the way. If the first part of the probe is flexible you may get it to emerge at the front if the box section bends, perhaps via the hole for the wiring for the electric jack on the A-frame.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-24-2020, 09:55 AM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
I have used flexible conduit to rum wires to the back of the Airstream. It is quick, easy, and efficient. I just zip tie the conduit to whatever is available along the desired route.
I am not a big fan of powered stabilizers. Adding another system to malfunction is not my thing. I use a DeWalt 12 volt drill/driver to raise and lower Lucy's stabilizers. I also carry a DeWalt impact driver. It is not a good idea to use this tool on your stabilizers as it will disrupt the peace and quiet of the entire campground.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 05-24-2020, 01:31 PM   #12
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
You haven't mentioned which power stabilizers you are looking at. Home Depot carries the same unit Airstream uses. I mean exact same, switches and all.
https://www.homedepot.com/p/Lippert-...8707/307896684
About half what my dealer quoted. Because it was a replacement changing it out was rather simple. Four bolts, two wires you're done.
cbburke is offline   Reply With Quote
Old 05-25-2020, 07:56 AM   #13
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Great Idea!
[QUOTE=cbburke;2363292]You haven't mentioned which power stabilizers you are looking at. Home Depot carries the same unit Airstream uses. I mean exact same, switches and all.
About half what my dealer quoted. Because it was a replacement changing it out was rather simple. Four bolts, two wires you're done.[/QUOTE
Thank you for the link! This will be a great addition to our AS. I almost purchased a GT because of this feature but liked the Serenity interior better.
Mikebrady62 is offline   Reply With Quote
Old 05-25-2020, 08:21 AM   #14
2015 30' Flying Cloud
Port Sanilac , Michigan
My dewalt cordless drill with torque set to 11 gives a perfect stabilizer deployment every time.
pontzdav is offline   Reply With Quote
Old 05-25-2020, 08:54 AM   #15
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
I used and extension cord. It is made to protect the wires from the elements and is less expensive than buying the wires. Just make sure the gauge of the extension cord is the right one for the load.
coolbabe is offline   Reply With Quote
Old 05-25-2020, 11:07 PM   #16
SlvrTwinkie's Avatar
1976 29' Ambassador
Logansport , Indiana
Holy cow Batman, through HD you can two for about half the price of one at the RV Supply websites. When it comes time to replace our stabilizers I will order them through HD. But as for running the wiring, I have to agree if you can run them inside for the main run, that is a way to go. But than again if you decide to run under the trailer, attaching them to something already there will work too. I would see about maybe running a 7 or 8 wire cable. like umbilical cord, that way if you decide to add more lights or add other things that need 12v power you will have the extra wire there already to be able to put new additions on their own circuits. But that's me prep ahead of time when possible.
SlvrTwinkie is offline   Reply With Quote
Back (2) running Lts. work, front (2) don't ? Danny Bell Lights - Interior & Exterior 0 05-27-2015 03:59 PM
Firan Ultrastar Class A RV Arched Roof Like Air Stream Very Very Nice eBay Watch Airstreams on eBay 0 03-29-2012 11:10 AM
Squarestream 5th wheel - all aluminum! very,very rare! wanderer1 All Squarestream Trailers 20 01-07-2008 08:10 AM
very old and very new horsefoot Member Introductions 4 10-02-2007 07:43 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
