RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-26-2020, 10:20 AM   #1
2014 27' Flying Cloud
Springfield , Illinois
Right Turn Signal Lights When Store Switch Is On
2014 27' Flying Cloud My Airstream was connected to shore power to top off the batteries. Noticed this morning several of the right turn signal LED lights were dimly lit and seemed to be fluttering. I disconnected shore power and turned on the "store" switch. It is my understanding the only electrical activity with the store switch activated is the carbon monoxide detector and the trailer's braking system. I connected the trailer to my truck and checked the lights. Running lights worked as expected as does the left turn signal. The right turn signal functions but the lights that were lit without the truck being connected did not blink. The same lights on the left turn signal blink correctly.
What would cause some of the right signal LED lights to be lit while connected to shore power and when in the store-mode?
nmiller314 is offline   Reply With Quote
Old 10-26-2020, 11:29 AM   #2
Silvr_Bullet's Avatar
42 2' 27" N / 74 7' 6" W , US
I had a similar issue, rain water entered the seven way connector causing it. I purchased a cap for the seven way and store the seven way cap up with reusable plastic tie alongside power jack, water cant enter it.
Silvr_Bullet is offline   Reply With Quote
Old 10-27-2020, 08:55 AM   #3
Thank You
That makes some sense. Temperature was in the 30s and humidity increased during the day. The lights were very dim early in the day and grew brighter as humidity increased. Harness connector was facing toward the ground but some sort of condensation would account for the short allowing the lights to be on.
Old 10-27-2020, 09:16 AM   #4
If you decide to purchase the cap, storing your connector as you mentioned will not keep water out totally, mine isnt waterproof. Store if facing skyward. Added benefit helps keep dirt away from contacts.
GR Innovations 7 Way Plug Cover | Plug Saver https://www.amazon.com/dp/B01AMON6HM..._HQcMFb0HPHZSQ
Old 10-27-2020, 09:43 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
This came with my replacement Husky jack.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 10-27-2020, 10:50 AM   #6
wilsodf's Avatar
Paramus , New Jersey
Here is what we use, keeps the plug nice and dry. Click image for larger version
wilsodf is offline   Reply With Quote
Old 10-27-2020, 11:36 AM   #7
2019 27' Globetrotter
Denver , North Carolina
What Bob said he uses above, but a little cheaper.
https://www.amazon.com/HUSKY-TOWING-.../dp/B01MFFC0IU
Works well for us.
Dave S
link2dks is offline   Reply With Quote
Old 10-27-2020, 01:46 PM   #8
I do like this one better. Ordered one.
Old 10-28-2020, 08:15 AM   #9
Harness Connector Cover
Thank you all for the advice. I ordered the Husky cover. Weather is better today so I'll take my wife's blowdryer out to dry the connector.
1973 Overlander right turn signal Lothlorian Lights - Interior & Exterior 3 04-06-2012 11:14 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 03:01 PM
NEWB, Right turn signal and brakes come on?!? steven2themax Brakes & Brake Controllers 11 08-10-2010 01:01 AM
Rear right side turn signal not working s4misfaction Argosy Motorhomes 4 05-27-2010 04:39 AM
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 4 11-30-2004 10:09 AM
