Old 06-29-2021, 06:43 PM   #1
1987 32' Excella
Barnesville , Georgia
Replacing the wire to AC
I want to run new wires to the AC on my 87 excella, it currently has the either AC or the Microwave switch. I have spent the last hour searching the forum for some one who has actually accomplished this routing with out success. I (actually my electrician) am planning on adding a new SquareD box just like original in the storage compartment where the Current 30 amp shore power cable comes in. I have a new 50 amp shore power, that will feed this box. He will install a 30 amp circuit breaker that will feed the original Box, and (3) 20 amp circuit breakers( one for AC, 1 for hot water heater and a spare) I just need advice on getting wire to the AC. Thank you in advance
High-pockets is offline   Reply With Quote
Old 06-29-2021, 07:11 PM   #2
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
You could run the additional circuit to the 3 way switch if that's more accessible, then add a junction box and splice in the one that goes to the AC. The switch box could become the J box since you won't need the switch any more, although it may not be big enough for 4 Romexes and wire nuts. If they are all 12 AWG you will need 20.25 cubic inches.
You could also pull a new circuit to the microwave leaving the original one for the AC and just splice it together in the switch box leaving only two cables in there allowing for a box of 11.25 cubic inches min. To me this sounds like the best approach. Either of these choices eliminates trying to get wire thru the ceiling.
Brian
ITSNO60 is offline   Reply With Quote
Old 06-30-2021, 04:23 AM   #3
1987 32' Excella
Makes sense, I believe I can run it around and under the curbside twin, under the closet and into the cabinet where the microwave is located. I really appreciate the advice!
1987 Excella ( current)
1971 Excella, (sold), 1973 Excella (sold)
1988 34’ Limited (sold)
2016 Redwood 39 MB (Fulltime in this one)
2001 Carriage LS (part timer at lake Sinclair)
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Best wire connector for 12 gauge stranded wire jcarnevale Lights - Interior & Exterior 6 04-14-2014 08:18 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
