Old 07-07-2020, 09:17 PM   #1
2017 16' Sport
Surrey , British Columbia
replacing failed USB wall outlet
Several USB outlets on our 19 International have failed. I cannot seem to locate a supplier for these two-outlet, round, wall mounted outlets which are DC wired.
I wondered too if these USB outlets are protected by a single fuse in the DC distribution panel.
I would appreciate any advice on matters relating to these USB outlets. We have three of these double-USB outlets.
Thank you.
brine is offline   Reply With Quote
Old 07-07-2020, 09:21 PM   #2
2007 22' International CCD
Search “blue sea systems” and have a look at their marine-grade USB charger outlets. They are better quality and water resistant. Blue Sea also makes lots of 12 volt electrical goodies.
Check the fuses in your 12 volt power center for blown fuses.
rmkrum is online now   Reply With Quote
Old 07-07-2020, 09:30 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Another product to consider:
https://www.qsradio.com/shop-now.htm...ger/p/67959244
Note: I have never used one of these and I cannot say whether the quality is good or bad.
SSquared is online now   Reply With Quote
Old 07-07-2020, 09:35 PM   #4
I have used many of their products. Aside from a lack of water resistance they are decent quality and reasonably priced.
I’m a ham radio operator, as is the owner of Quicksilver Radio...just to be upfront. I buy a lot of ham radio stuff from him.
Old 07-08-2020, 08:21 AM   #5
2015 28' Flying Cloud
Newtown , Pennsylvania
The USB outlets in mine are pushed into standard 12 volt cigarette lighter outlets. Airstream glues them in with a dab of hot melt glue. Once pried out with a screwdriver, replace them with a new one.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 07-08-2020, 10:15 AM   #6
Troy McLure's Avatar
2016 23' Flying Cloud
Portland , Oregon
+1 on the Blue Sea Systems. Every single USB outlet in our '16 23D went dead within about 18 months. I installed a 4-port Blue Sea Systems panel next to the DVD player. Easy install & works like a champ.
Troy McLure is offline   Reply With Quote
Old 07-08-2020, 10:35 AM   #7
pjshier's Avatar
2017 27' International
Wasilla , Alaska
A few weekends ago I discovered my favorite location for phone charging (by the a/v stuff over the table) was inop and the phone was almost flat. Moved the phone and cord to the one by the bed - same. Swapped to new charging cable - all good. Might check your cable.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 07-08-2020, 01:17 PM   #8
2015 25' Flying Cloud
Portland , Oregon
My Airstream dealer Parts Dept had the USB plug replacements.
KellyRice is offline   Reply With Quote
Old 07-13-2020, 05:49 PM   #9
I me the these:
Magnadyne Black Wall Mount 4 USB... https://www.amazon.com/dp/B00ZOG6TBE...p_mob_ap_share
RV WALL MOUNT 12V-VPA SOCKET/5V4A... https://www.amazon.com/dp/B00XDDGCOE...p_mob_ap_share
LB_3 is offline   Reply With Quote
Old 07-13-2020, 06:06 PM   #10
2020 25' Flying Cloud
Yamhill , Oregon
X2 on QSRadio.
They are slightly larger diameter by about 1/16” but a light round with a wood rasp and you are good to go. I actually replaced the USB at the bed with lighter socket so I could run my bipap.
Rob. K7RBE
Rob Edgerton is offline   Reply With Quote
USB outlet addition steilkurve Batteries, Univolts, Converters & Inverters 16 05-15-2020 08:56 PM
USB Outlet that supports Samsung Fast Charge kittmaster Electrical - Systems, Generators, Batteries & Solar 29 02-12-2020 11:26 AM
2016 FC23D USB outlet next to DVD player Atsushi Electrical - Systems, Generators, Batteries & Solar 6 11-30-2018 03:18 PM
USB Wall Charger, Has anyone successfully installed one? Retail6 Computers, Internet & Satellite 23 09-18-2015 09:30 AM
Water on floor, wall, seat, outlet nesvt General Repair Forum 16 07-24-2012 09:04 AM
