RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-02-2020, 01:48 PM   #1
1972 31' Sovereign
replacing breaker box
We are looking replace the old Airstream 30 amp breaker box and am looking to use an off-the-shelf breaker control box (i.e. not one made specifically for RVs) -- curious if anyone has done this. For the 12V circuits I plan to use a simple LED 12V driver (fed by one 120V circuit coming off this breaker box); the remaining available circuits will feed the 120V outlets and appliances (AC system). Might add a few new 120V outlets around the trailer as well. If/when we add solar and batteries, we will have adequate space in the breaker box to accommodate. Our trailer is going to be a park trailer so no batteries to incorporate (not yet at least) involved -- we just want the 50 amp (and/or 30 amp) service supply found at RV parks. We are eliminated the Univolt.
In examining the new breaker boxes that are available from Home Depot/Lowes, it appears that the ground bus and the neutral (white wire) bus are one-and-the-same, while the small 30 amp service box we are replacing (the original Airstream box) has the ground wire bus connected to the steel breaker box, while the neutral white wires have their own bus (and don't appear to be electrically connected to the grounded steel box.)
Any thoughts or guidance would be appreciated!
learthman is offline   Reply With Quote
Old 02-02-2020, 02:00 PM   #2
2007 22' International CCD
Electrical code and good wiring practice require the neutral and ground buss bars to be isolated in a trailer. Itís a safety thing to avoid a Ďhot skiní condition if you plug into a miswired pedestal or outlet. An accidental hot-neutral swap in the pedestal can easily put line voltage on the outside of the trailer, which can be fatal...which is why I have an EMS/surge protector hard wired into my trailer. My power relay doesnít close and power even come on unless itís wired right and the right voltages.
They may make an isolated neutral buss bar for your box. Check with the manufacturer of the box or a real electrical supply house. The home improvement folks may not be aware of the issue and carry the part. It sits in insulated blocks and should screw right into the correct box.
rmkrum is online now   Reply With Quote
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box 59as Airstream Classifieds 0 09-19-2014 12:01 PM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 09:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 09:37 PM
Breaker Box for Sale jlawrence Electrical - Systems, Generators, Batteries & Solar 1 04-25-2004 10:48 AM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 11:21 PM
