RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-30-2018, 05:46 PM   #1
1961 22' Safari
Collegeville , Pennsylvania
Replacing a two-prong 120V outlet
I'd like to replace a two-prong 120V outlet in my 1961 Safari with a 3-prong outlet but I'm not sure what to do with the ground on a 3-prong outlet. It still has the original wiring.
I've read where you can replace a two-prong outlet with a GFCI (with a "No Equipment Ground" label).
I haven't checked the electric box but when I connect to shore power, is the frame (and shell) connected to the ground? Could I just connect the ground terminal on a standard 3-prong outlet to the shell / frame or is it better to leave it not connected to anything and go the GFCI route?
Anyone know the proper way to handle this situation?
Thanks!
TheHandyDan is offline   Reply With Quote
Old 06-01-2018, 06:14 PM   #2
2011 22' Sport
Portland , Oregon
Might want to see this thread: http://www.airforums.com/forums/f37/...ts-179729.html
You can also do a search within the forum for GFCI to see other times this has come up.
SilverHouseDreams is offline   Reply With Quote
Replacing 2 prong electrical outlets. ttbikes Electrical - Systems, Generators, Batteries & Solar 16 04-08-2018 09:48 AM
Two Prong Outlet and Voltage Monitor ttbikes Batteries, Univolts, Converters & Inverters 4 05-30-2016 10:35 AM
Vintage trailer with two prong outlets BambiTex Batteries, Univolts, Converters & Inverters 6 03-11-2015 03:08 PM
Bargman #99 Tailight refit 6-prong to 7-prong silverkeeper 1960 Safari 6 03-05-2011 11:01 AM
3-prong plug converter to fit in regular outlet codybear Off Topic Forum 13 08-21-2006 10:00 PM
