Old 05-07-2021, 06:28 PM   #1
1988 25' Excella
louisburg , Missouri
Replace power converter
I have an old BW Manufacturing power converter.
Series 32, Model 3230ul that has stopped working. Can anyone recommend a replacement? Thanks in advance.
dtutko1 is offline   Reply With Quote
Old 05-07-2021, 07:53 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I have installed Progressive dynamics PD9245 in both of my trailers, as well as several for friends. They are easy to change out, reliable, and have a good warranty. I have had good luck with all that I have installed. great support from the company. JMHO
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-08-2021, 06:58 AM   #3
1988 25' Excella
My existing be converted charger has 5 or 6 fused circuits for 12 volt distribution thru the airstream. From the pictures and description the Progressive doesn't seem to have them. What do I do?
Old 05-08-2021, 07:23 AM   #4
2019 30' Flying Cloud
Grass Lake , Michigan
You could add a fuse panel to serve those circuits if there's a location nearby to mount it. Many different ones available online, A simple search for "12v fuse panel" on Amazon will get you way too many choices.
oldenavy is offline   Reply With Quote
Old 05-08-2021, 07:58 AM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
What model is the BW converter? There should be a seperate 12 volt distribution panel in the trailer, fed by the converter. Do you have the owners manual?
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 05-08-2021, 08:45 AM   #6
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Are the fused circuits integral to the old converter or is it a panel that can be removed and used with a new converter?-- Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
2017 converter vs. 2018 converter. Mollysdad Batteries, Univolts, Converters & Inverters 14 06-01-2018 06:11 PM
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
