When I took my 2016 Airstream Classic out of storage this year, I swapped out the Atkinson solar controller with a Victron 100-30 solar controller. I also added a third solar panel to the factory installed solar system. Everything works great except now the 3 LED lights over the sofa and the two LEDs in the storage cabinet above sofa the don't work. I checked all the fuses, they're all fine. I cut loose one of the cabinet lights and hooked it to a
12 volt battery. The light works. I used a non-contact voltage sensor and it shows voltage present. I traced all the wires and tightened all the connections, cleaned and checked the ground on the outside of the trailer with no results. Everything else works. Do anyone have any ideas?
I'll be forever grateful for any input.
