White turning the valves to hot water heater I notice two RCA plugs red and while They are not hooked up ? Just laying on the floor under the couch panel where the access hole is located. I wonder where the other ends are and what are they intended for I thought maybe for a subwoofer? Thanks Wayne
Yes, subwoofer. You should also have a power cable and blue auto-on cable that triggers the sub power when you turn on the radio. The stock sub is meh. Get a bazooka powered sub which works well, great for movies.
Yep, I was told my mystery RCA plugs were for a sub woofer if installed. I also have mystery wires to nowhere under my sink and bed.
MICHAEL
