Old 05-07-2020, 10:43 AM   #1
2010 27' FB Classic
N/A , Texas
Questions about towing without batteries in trailer
I have never taken the batteries out of my 2010 trailer. They seem to still be in good shape but since I won't be traveling during these virus times I will take them out and just put them on a maintainer till I need them again. So that brings me to my questions:
1) Can I still just hook up to the truck and still have lights and brakes just with the 12v electrical cord from the truck?
2) Do I need to separate the battery connections inside the trailer so the pos. and neg do not touch when the trailer is just hooked to the truck.
The reason for my questions are that I may need to get the trailer inspected and will need to tow it to the inspection station and I'd like to tow with no batteries in it. The inspection will not happen anytime soon and the batteries will already be on the bench and not in the trailer.
"There’s two kinds of people, them goin’ somewhere and them goin’ nowhere. And’s that what’s true". -Ben Rumson
Old 05-07-2020, 10:45 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Your emergency brakes via the disconnect switch require you to have an onboard battery to function. If the truck and trailer become disconnected the emergency trailer brakes WOULD NOT function without an onboard battery.
Hope this helps.
GMFL is online now   Reply With Quote
Old 05-07-2020, 10:48 AM   #3
2010 27' FB Classic
N/A , Texas
Thanks forgot about the safety brake.
Old 05-07-2020, 05:55 PM   #4
2019 28' International
Going Where , The Climate Suits Our Clothes
The lack of safety brake while towing pretty much says it all. But I would point out that the inspection is likely to involve inspecting that breakaway switch as well. So it would fail the inspection without the battery.
Beerboy is offline   Reply With Quote
Old 05-07-2020, 06:23 PM   #5
2018 25' International
Slidell , Louisiana
It should be a non-starter due to above, but fyi the lights and things would function through the tow vehicle connection, up to about 20Amps, if you keep the positive post separate and isolated from the frame. It will likely blow the fuse in the tow vehicle if you don't.
Old 05-08-2020, 10:02 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
"Safety First" need the battery for the Breakaway switch as stated above. So don't leave home with out them
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 05-08-2020, 02:40 PM   #7
SHE SHED
trikdacy's Avatar
2019 30' Classic
Brooklyn , New York
Good question. Good answers. Thanks for the info.
trikdacy is offline   Reply With Quote
Old 05-09-2020, 04:07 PM   #8
1995 28' Excella
Seguin , Texas
Before you run off to the inspection station, check the top right corner of the license renewal notice. After I had my trailer inspected, my wife noticed “Inspection not required.”
First time in 35 years of towing that I have seen those words.
DGBMLB is offline   Reply With Quote
Old 05-09-2020, 04:46 PM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Yep you need the batteries. Especially for your emergency brakes
Towing without coach batteries bimmersbeercan Towing, Tow Vehicles & Hitches 9 02-06-2019 01:46 AM
Towing without batteries Patti G. Batteries, Univolts, Converters & Inverters 4 03-09-2017 09:46 AM
12v without batteries Sirwalshalot Electrical - Systems, Generators, Batteries & Solar 10 12-08-2016 11:01 AM
Storing Trailer Without Batteries greatlakes Batteries, Univolts, Converters & Inverters 6 04-24-2011 12:23 PM
Trailer Use Without Batteries . poorboycjs Electrical - Systems, Generators, Batteries & Solar 1 05-27-2004 04:52 AM
