Old 05-21-2020, 08:20 PM   #1
Hygge Hus
rspecialk's Avatar
2016 30' Classic
Johnston , Iowa
Question about PI EMS-PT50X
Through recommendations on this site, I sprung for this unit. I am using it for the first time and there are codes that cycle through. The important one is E0 as it means there are no errors. However, I can't find out on their website what some of the others mean. Can anyone help? This is the cycle:
60 HZ (60 Hz strength which is correct amount?)
E0 (I know this means there are no errors)
L-1 (probably means Line 1)
124 (voltage?)
2A (???)
L-2 (probably means Line 2)
125 (voltage ?)
2A (???)
I guess I am not sure why there is a code of 2A. The rest I can guess.
Thanks for clarification. I know it probably doesn't matter but I would like to know Thank you.
Lynette Rasmussen
rspecialk is offline   Reply With Quote
Old 05-21-2020, 08:33 PM   #2
2018 25' International
Slidell , Louisiana
For the benefit of other readers this is a Progressive Industries Surge Suppressor.
60Hz is the frequency of the AC line. Power from the US national grid will always be exactly 60 cycles per second. When you are getting power from a stand alone generator, the frequency may not be stable.
L-1 is indeed line one one of the two live 120 nominal lines
124 is the RMS voltage. 125 is the high target voltage 110 is low.
2A is the current draw in amps on L-1 probably a light charge from the converter to supply the 12V load.
L-2 is indeed line 2
125 the voltage, Note L-2 Voltage is 180 degrees out of phase of L-1
2A the current draw on L-2 probably powering the refrigerator.
Progressive Industries EMS-PT50X full of water? stevejones Electrical - Systems, Generators, Batteries & Solar 22 05-24-2019 11:21 AM
Interstate EMS System Questions FlaBucki Sprinter and B-van Forum 5 04-08-2019 08:44 PM
Question about Installing EMS Electrical Protection jec1 Electrical - Systems, Generators, Batteries & Solar 1 09-07-2018 11:02 AM
Ems-hw50c cwf Electronics & Connectivity 1 03-26-2015 03:58 PM
EMS from Progressive Industries markjoandall Electrical - Systems, Generators, Batteries & Solar 0 08-02-2005 07:14 AM
