Old 06-13-2024, 06:05 AM   #1
2021 30' Globetrotter
Forest , Virginia
Puzzled
BR receptacles, TV, Fusion and microwave not working while plugged up to good shore power. Breakers seem fine. Receptacles and tv will power up if the inverter is switched on. I also donít have a yellow light indicator displayed on the inverter panel even though Iím on shore power.
vsp1593 is offline   Reply With Quote
Old 06-13-2024, 09:19 AM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
You might want to check out this recent thread where someone had a similar issue. It has a lot of good advice on how to diagnose a problem with the shore power not working properly.
Otherwise, I'd guess with a 2021 you have a Smartplug, it will have a blue light if it is getting good power (red is reverse polarity). If not, then it's your power source or cord. If it is then check at the panel if there is AC voltage coming in (see multimeter tips in the above post). Basically, find the spot where there should be a voltage but there isn't.
The inverter runs off batteries and is powering its outlets as it should, so that doesn't tell you much.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 06-13-2024, 11:42 AM   #3
2019 30' International
Pennsylvania , Pennsylvania
Check the gfci outlet.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 06-19-2024, 11:10 AM   #4
Forest , Virginia
Problem solved but still a mystery
I had read on another forum to cut the breaker off at the box and also turn off all breakers inside on the panel before cutting them all back on, one at a time. I tried this and the same issues remained.
So, we unplugged and packed up to travel our next leg of the trip. Upon arriving at the next site, I plugged up everything as usual and everything worked. No idea what caused the original malfunction, but it's solved for now.
Old 06-19-2024, 12:21 PM   #5
2017 25' International
West Lake Hills , Texas
Might have been polarity swapped. I've started using a receptacle tester before plugging in, even though I have an EMS.
Fungus is offline   Reply With Quote
Somewhat puzzled by converter? Anniedog Batteries, Univolts, Converters & Inverters 7 09-15-2009 08:24 AM
water system has me puzzled stillworkinonit Water Heaters, Filters & Pumps 0 06-06-2007 06:00 PM
puzzled by fuse at battery connection Tin Tortuga Electrical - Systems, Generators, Batteries & Solar 2 03-25-2005 03:13 PM
Puzzled by peeling SCBrat Upholstery, Blinds, Walls & Interior Finishes 12 10-15-2003 07:37 PM
