Old 04-26-2021, 05:44 AM   #1
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Programming a BMV correctly
I have spent the better part of a month studying the Victron BMV 712 and how it functions.
There have been many people whom have experienced the “drift” in SOC reporting these little guys have over time and in a few cases there have been reports of large shifts in the SOC in a single day.
I believe I have determined the cause of these problems and come up with some settings that will improve the reliability of the BMV’s reporting.
This is especially important if you have a Larger capacity battery bank and charge via MPPT/Solar for extended periods of time.
Here is a 15min video laying out each setting with extreme detail.
Watching this video will hopefully help you understand what each setting means and better understand how your BMV works
Old 04-26-2021, 06:56 AM   #2
2019 25' International
Providence , Senior Electrical Engineer
This is timely information. I would also "suggest" that you create an additional post that shows 3 table sets. Lead Acid, AGM, Lithium. Granted the Battery Capacity of each bank will vary, but the other details may be more useful to those that are looking over the internet to determine what is "best".
I know I did that and used the AM Solar profile for my 200AH AGM factory solar setup. Most people are looking for "where do I start"....and even as well as the video defines great info, people will still be looking for "what values should I start with".
The other thought I had is that not everyone has the temperature sensor, I had to buy mine additionally, it isn't the default when you buy the "kit" from say...amazon...it's an option adder.
Just a thought....and a very informative video.
I do have a BMV question about this unit, but off topic to this post...Will PM you.
kittmaster is offline   Reply With Quote
Old 04-26-2021, 09:52 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Great video, your explanations on the settings help clarify what's going on with the system.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 04-27-2021, 07:20 AM   #4
2021 30' Globetrotter
East Northport , New York
Thanks for this Ronnie!
One question. I'm using a Cerbo GX and Lynx shunt. I don't see the "battery starts synchronized" option using the remote console (I don't have the GX Touch 50). Is that option not relevant to the Lynx shunt or am I missing something?
James
Biker is offline   Reply With Quote
Old 05-04-2021, 03:51 PM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Correct, I do not think that option affects the Lynx shunt.
Old 05-04-2021, 04:25 PM   #6
Sent you a PM, if you get a chance can you take a look? Thanks.
Chris
Programming a memory button Bbelk Jacks, Stabilizers, Lifting and Leveling 2 08-27-2019 04:51 AM
ECU Programming Camerons Sprinter and B-van Forum 39 10-02-2017 08:34 PM
How do I reset the dometic AC programming? k9jackie Sprinter and B-van Forum 2 05-09-2015 05:29 PM
HVAC System Programming/Installation Problem PlanoSilver General Repair Forum 1 12-06-2014 03:38 PM
PCM programming or chip for more HP and MPG LI Pets Tow Vehicles 2 11-16-2006 04:05 PM
