Old 05-02-2021, 10:00 AM   #21
Lake Oswego , Oregon
Originally Posted by Bmccorm View Post
I just use a regular outdoor extension cord and a Battery Maintainer…
Not familiar with the term Battery Maintainer?
Please elaborate
pnwyankee is offline   Reply With Quote
Old 05-02-2021, 10:55 AM   #22
DKB_SATX's Avatar
Alamo Heights , Texas
Please elaborate
They are essentially specialized battery chargers, usually they are only capable of low amperage though some of them can run the full cycle between a charge and a maintenance trickle. They maintain batteries in storage without overcharging them.
Fancier ones are designed to round-robin through more than one battery so you can maintain multiple batteries in storage with one device without having an interaction if one of the batteries is different size or age or has a dead cell. BatteryTender and Noco Genius are common brands.
— David
DKB_SATX is online now   Reply With Quote
Old 05-02-2021, 10:59 AM   #23
Sag Harbor , New York
Can anybody suggest a product I can purchase that will enable me to make this connection?
Wondering if you [OP] found an adaptor which worked with your outlet cover?
Old 05-02-2021, 11:59 AM   #24
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Hi
If the converter is hooked to 110V on one side and the battery on the other side, then that's ON. If it is in this state 24/7 then that's "always on".
Does this apply to all circumstances or just when unoccupied?
If the former, what should full-timers or long term snowbirds that sit plugged in at the same spot for months at a time do regarding their internal converter?
Greg
greghoro is offline   Reply With Quote
Old 05-02-2021, 12:12 PM   #25
DKB_SATX's Avatar
Greg
An actual battery disconnect would work with relatively modern converters (say 90s and newer)... the converter would continue to supply the 12v bus but the batteries wouldn't be exposed to the converter output. The buzzy old boat anchors needed a battery in the system to smooth out the output.
With a really modern (3-stage) converter when you're actually using the trailer often or always, this isn't a big concern because it's easy to check battery levels and smell or hear if something's amiss.
— David
Old 05-02-2021, 08:32 PM   #26
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I changed out the factory installed converter to an three staged battery charger. I have an 30 amp to 15 amp adapter that plugs into the trailer then I have just a heavy duty cord that plugs into the storage electric. Yes I leave my trailer plugged in 100% of the time it’s in storage. I check on battery water about ever two months if we don’t use it. My AS is an 2009 that AS installed a one stage battery charger (bad) What year is your AS and do you know what type of converter you have???
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 05-03-2021, 05:36 AM   #27
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Greg
Hi
If you are in the trailer "doing stuff" then the battery is seeing a normal use cycle. It's not sitting there simply getting blasted at full charge by a gizmo that wants to charge it a bit more ....mIndeed, you still see some impact.
In a "stationary" 24/7/365 sort of setup you probably want to get rid of the battery entirely. You no longer need it for the break away function. You also would go with a very different 12V source.
Plugging into 110 Power Dickandvicki Electrical - Systems, Generators, Batteries & Solar 10 04-30-2021 02:08 PM
plugging inverter into 12v socket for 27 watt TV jackvosney Batteries, Univolts, Converters & Inverters 2 06-20-2018 09:36 PM
plugging into city power plus latch story Jjona5 Argosy Motorhomes 2 07-04-2017 06:26 PM
Blowing Fuses When Plugging Into Shore Power 1hank1 Electrical - Systems, Generators, Batteries & Solar 1 04-24-2012 08:29 PM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 09:57 AM
